07-21-2009, 07:33 PM | #1 |
Newbie Join Date: Apr 2006 Location: West Bloomfield
| WK Popping noise
When I get my wheels jammed up and give it some gas I start hearing a little popping noise which sounds like a gear slipping/stripping. What is the likely point where this is coming from? Thanks in advance. |
07-21-2009, 09:14 PM | #2 |
Rock Stacker Join Date: Jul 2009 Location: Orlando
I think it could possibly be your slipper gear inside your tranny but to be sure you would have to take it apart and check it could be any gear in the truck slipping. Since you said it happens only when the tires are jammed up then I would say it might be one or both of your axle differentials.
07-21-2009, 11:08 PM | #3 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
most likely your slipper is worn. WK Tranny Fix this is a sticky at top of WK page, read it.
07-22-2009, 03:52 PM | #4 |
Rock Stacker Join Date: Mar 2009 Location: Lattimore, NC
I just experienced the same problem, and it turned out to be the rear differential gear set. at least that is what I experienced and it wasn't the tranny. if you have four wheel drive you will most likely need to look into both ends.
07-27-2009, 02:13 AM | #5 |
Newbie Join Date: Jul 2009 Location: bloomington
make shure all ur diffrenitial housing screws are tight that what did it for me
