03-20-2010, 07:13 AM | #1 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
| Sexy EASY CLEAN Trans Slipper MOD
This worked so well I wanted to make its own thread. I do not see how it could get any easier. Part Numbers: Hpi Blitz Trans Top Shaft (5 x 48 mm) #103375 Hpi Blitz Slipper #103377 Hpi Blitz Spur Gear (88 Tooth) #103373 HPI Z263 (You may not need these but they are good to have) 1st line up the Blitz Top Shaft with the Stock WK/CK Top shaft. What you want to do is drill a hole the same size as the stock one for the Pin for the Gear to set up on. Just center punch the same length from the rear as Stock and put in a Vise and drill the hole. Next take a dremmel and cut a groove in the back end of the shaft for the E-Clip. Lock up the Middle Gear and That's it now just put it together. Dust Cover still fits on correctly. You can even drill out a hole in the Dust Cover so you can make adjustments. I filed the screws down and the plastic here just for some more clearance. Here you want to Lock up the Middle Clicker Gear . I just put some shock spacers in there with some JB Weld. |
03-20-2010, 09:50 AM | #2 |
Rock Stacker Join Date: Nov 2009 Location: West Mobile
You are the man!! when I get some time gonna make one. Your directions were good, the first step took me a minute to figure out with the pics though. Showing the two top shafts together would have cut down on my confusion, but I never claimed to be smart.
03-20-2010, 09:52 AM | #3 |
Yeah the top pic shows the Blitz Shaft complete compared to the Stock Shaft, Sorry. I would think this would be a sticky but I think the biggest Spur Gear you can use is a 88 tooth. THANX, Its super easy.
03-20-2010, 02:25 PM | #4 |
Quarry Creeper Join Date: Feb 2010 Location: Nevada City, CA
Wow, NICE JOB !! This is super clean install-fab !! So far I like this slipper the best and it uses HPI parts. Is the Blitz spur gear still 48 pitch ?? I would think that maybe a aftermarket company like Robinson may make larger spur gears.
03-20-2010, 03:09 PM | #5 |
Yeah 48 pitch, I have not found any larger spurs for the Blitz. They have to be Blitz specific cause how the Pads sit. Thanx |
03-20-2010, 05:05 PM | #6 |
Do you think that running your slipper with the hpi GRU and the 88t spur would work for crawling? I am trying to make my crawler better. Thanks
03-20-2010, 05:19 PM | #7 |
A slipper is not the best for just crawling unless you tighted it up all the way. On my old crawlers I would tighted the slipper up all the way then back it out 1/2 turn for some protection. The 88 Tooth Spur is not going to the best for crawling although you could do it. The stock Crawler King is a 90 tooth.
03-21-2010, 06:40 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
What size shock spacers were used in locking up the middle clicker - in mm if you could? Thanks! BTW: sweet mod and directions |
03-21-2010, 06:48 PM | #9 |
| Man I do not know the MM but it is the next to smallest size. They fit between the layers you could use the larger ones too. I think that Mod is on here somewhere. You could just Use JB Weld in there only. I used both as not to use so much JB Weld. Its Easy as long as the spring cannot compress, use what you got. Do not think too hard on it, Its Easy.
06-22-2010, 04:39 PM | #10 |
Still holding up nicelyIf you have not done it yet, you need to. Later
06-22-2010, 11:46 PM | #11 |
I performed this mod and it has been awesome !! I haven't broken any axles or trans gears since the install !!! And I was breaking front axles almost every crawl session !! Super easy to do !!! Thanks skullking !!!!! |
06-26-2010, 05:53 PM | #12 |
Newbie Join Date: Jul 2009 Location: Mandaluyong City, Philippines
This a great mod! Thanks for sharing! |
07-03-2010, 11:40 PM | #13 |
Newbie Join Date: Jan 2009 Location: USA
Any tips for cutting the groove? I have access to a Dremel tool but I've never used it for something like that. I'm still waiting for my Blitz shaft in the mail (could be a while since it hasn't shipped yet and 4th of July).
07-04-2010, 05:51 AM | #14 |
I just put the shaft in a vise and scribed my line on the shaft and carefully cut around. You just need enough for the e-clip to hold. I would get some steel rod roughly the same size from like lowes or home depot to practice on 1st. |
07-04-2010, 10:08 AM | #15 |
A practice rod sounds like a good idea. I drilled a practice hole in the stock shaft yesterday. It was perfect.
07-05-2010, 06:23 PM | #16 | |
07-05-2010, 06:32 PM | #17 |
07-06-2010, 10:51 AM | #18 |
Newbie Join Date: Jun 2010 Location: Lincoln, NE
| looks and sounds good
got the stuff on order for this mod, cant wait to try it out the only thing im concerned about is the 88t spur gear that has to be used. currently runnin a 96t gear. is 88 the highest u can go with the mod or can a 96t spur be moded to work with the blitz clutch? has anyone tried this? |
07-06-2010, 03:48 PM | #19 |
Yeah the Spur gear size will be a problem. I am not crawling with mine so it is O.K. for me.
07-10-2010, 11:43 PM | #20 |
I just use the HPI gear reduction unit to get around the fact there are only 88T spurs available.
