07-04-2010, 03:42 PM | #1 |
Rock Stacker Join Date: Mar 2010 Location: jacksonville
| hd running gear
does anyone know of any company that still makes hd ring and pinions and hd tranny gears for the wheely king im hoping to bullet proof my drive train
07-04-2010, 04:38 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: South Dakota
RCP still makes the ring and pinion with the buillt in locker.
07-04-2010, 10:35 PM | #3 |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
axial over and under drives
07-05-2010, 01:49 AM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
I believe Integy just came out with a HD ring and pinion, and HPI has a HD ring and pinion - I think from the firestorm that will fit.
07-05-2010, 05:40 AM | #5 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Hey guys I am interested too. The last time I bought hardened ring and pinion gears i paid over $50 for both axles. Prob is now I have 2 more axles that need hd gears. Post up some links to parts that are known to fit if u can. I am on my way to building a 6x6 and want to be sure my axles wont have the soft stock gears
07-05-2010, 10:58 AM | #6 |
has anyone had any luck with the ckrc metal tranny gears
07-05-2010, 04:06 PM | #7 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
The CKRC tranny gears hold up great to regular crawling. Just stay away from crazy brushless setups!! Here is the part # for the HPI HD gears. 86336 , taken from page 30 of the manual. I used them in my front axle and never had a problem with them. |
07-05-2010, 05:59 PM | #8 |
i think im running some pretty good tourque now i just hope the aluminum gears hold up i have a 35t lathe, 15/96 gears, ccsidewinder all on 3s
07-05-2010, 06:14 PM | #9 |
07-06-2010, 03:58 AM | #10 |
07-06-2010, 10:40 AM | #11 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
My aluminum tranny gears are still holding up great. I put them through rediculous amounts of abuse. They even helped me get 3rd place at the AWCC! TOM |
07-07-2010, 02:07 AM | #12 |
07-08-2010, 09:04 AM | #13 |
Newbie Join Date: Jun 2010 Location: Lincoln, NE
| clarification
I believe this to be the correct ones http://www.ckrccrawlers.com/hpi-heavyduty-final-gear-set-p1x38tp1x13t-p-2724.html |
07-08-2010, 04:56 PM | #15 |
yeah i would op for those too, didnt see those
07-08-2010, 08:19 PM | #16 |
so the axial and hpi stuff is iterchangeable
07-09-2010, 08:37 AM | #17 |
The only difference is the inner diameter of the inside recess of the ring gear is about 1mm larger on the Axial stuff. So if you buy a heavy duty spool/carrier (Felsenfest, Super 300) You will have to do some dremel work on the HPI gears. The bolt pattern and everything else is identical. No to mention, all the heavy duty gear sets are 5mm on the pinion shaft. So buy a set of MIP driveshafts for an AX-10, and then the 6mm ends (part number 8137) TOM |
07-09-2010, 03:44 PM | #18 |
Pebble Pounder Join Date: Jun 2009 Location: Canada
07-09-2010, 05:59 PM | #19 |
I've got 12/93 gearing with a 12turn Cobalt Puller on 3S lipo. You think YOU have torque, HA! But yeah, back onto tranny gears. The aluminum gears aren't the sweetest most indestructible gears, but they are the best one's on the market for the money. TOM |
