08-04-2010, 06:21 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
| rolling
kinda new... how do i stop the crawler king from rolling in "neutral"?
08-04-2010, 06:22 PM | #2 |
Get a ESC with a drag brake
08-04-2010, 06:53 PM | #3 |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
08-05-2010, 05:40 AM | #4 |
Lol... I knew that... not really though. Any ideas on an inexpensive esc with drag?
08-05-2010, 01:36 PM | #5 |
what is inexpensive to you? rooster crawler is like 90$ i'd suggest getting the holmes torque master. you won't need another brushed esc. |
08-05-2010, 08:08 PM | #6 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
You can get a CC Sidewinder for around $75. The stock motor also has limited holding power due to is weak magnets. A better motor would help the holding power. Another option would be to change to a higher gear ratio. Change the counter gear to a 96T and go to around 15T on the pinion. The added reduction will give the motor more drag. Top speed will drop a little though. |
08-05-2010, 08:18 PM | #7 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
X2 on stock motor, very weak magnets, you will still roll with a drag brake ESC, so you need ESC and a Motor.
08-06-2010, 01:26 AM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
Get the GRU, use a 27t HPI Saturn motor, and that sucker will just sit on top of the rocks in neutral. Even at 45 degree incline or decline!
08-06-2010, 10:22 AM | #9 |
Pebble Pounder Join Date: Jun 2009 Location: Shenandoah Valley, VA
I have a Reedy Stock Star 27T in my Honcho which holds very well. Not sure how it would hold in the WK with taller tires. FB9 magnets!
08-06-2010, 12:04 PM | #10 |
I know this is kinda off topic but its esc and motor related... I have a velineon bl system, is there a gearing I could use for crawling or is it just to fast?
08-06-2010, 05:06 PM | #11 |
08-06-2010, 07:27 PM | #12 |
i looked up the GRU and it says that they will work for BL setups but wont last long, espicially for fast motors... thanks for everybodys input!
08-10-2010, 07:08 AM | #13 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
rc4wd make the best esc i have ever bought and i run the novak bl 13.5 system right now but the price for the esc is 49.99 and the motors run 9.99 from a 35 t to and 80t http://rc4wdstore.com/2/product_info...53ee7bf29797ab http://rc4wdstore.com/2/advanced_sea...keywords=motor |
08-10-2010, 01:46 PM | #14 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
If you install the GRU it is not necessary to have a ESC that has drag brake. The GRU will give you more than enough braking power. I did that on mine and it works perfect. I can crawl downhill and I always have to apply throttle otherwise I wont move.
