09-12-2012, 07:52 AM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Australia
| Tekin 35t combo + 3s Lipo questions...
Gday, I have spent the whole day reading the boards here about brushed vs brushless and what the WK can handle. I am steering away from brushless as I want my car to be reliable. I am pretty keen on the Tekin 35t handwound + FXR combo with a 3s lipo battery, just had a few questions about this setup. Everything else in my wheely king is stock but I plan on installing stronger driveshafts and steel transmission gears. 1. Would this motor batt esc setup be faster and more torquey in everyway then the stock setup? 2. Could my wheely king handle it? if not what parts would be the first to break? 3. Are there any other parts that are required to install these components in my wheely king? 4. Is the ESC Waterproof? Thanks for your advice, heading to the outback next week so want to get it all setup for my trip, cheers. |
09-12-2012, 06:57 PM | #2 |
| Re: Tekin 35t combo + 3s Lipo questions...
1 Yes 2 no dogbones,followed by slipper, followed by plastic trans gears. 3 not that I know of 4 I dont know. |
09-13-2012, 11:39 PM | #3 |
thanks, I just bought the Tekin 35t hand wound. I aslo bought a 5000mah 11.1 v 3s Lipo, this battery would be OK to use yeah? Also, do I have to upgrade the stock WK receiver or will it be ok with this battery? Thanks |
09-14-2012, 06:36 PM | #4 |
The stock reciever will be fine, the esc only sends a limited amount of voltage to it. Sounds like a winning set up. Welcome to broken parts land, heeehee.
09-14-2012, 10:53 PM | #5 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
That setup should be pretty tame, that's what I run in my scalers. I'm not sure what a good gear ratio would be with the MT sized tires and 35T, just keep an eye on the motor temp and gear up or down accordingly.
09-15-2012, 06:31 AM | #6 |
cheers, good info. Ive also just bought front and rear hpi steel driveshafts, steel tranny gears, better servos, alloy steering knuckles and hubs and alloy steering linkage + HPI Diff locks. Are there any other parts such as the pinion gear that I should upgrade to cope with the power? Also does it make any difference to run better tyres and suspension? If so what setup would be best? What tread of tyre should I be looking for for bashing and crawling? thanks!!! |
09-15-2012, 08:42 AM | #7 |
the stock tires are great for bashing, not good for crawling A good combo tire would be prolines mashers, same style tread, but a softer compond. Or you could pick up some crawler specific tires and use the stock tires for bashing. For gearing I run a 15t pinion, 96t spur, mine is more a scalish crawler though. My suggestion is pick up several pinions and play with the gearing until you are happy with it and your motor is happy. Last edited by lonleycreeper; 09-15-2012 at 08:46 AM. |
09-18-2012, 03:17 AM | #8 |
Thanks, few quick questions on gearing, so the wheely king comes with a 96t spur standard? Is it worth getting a replacement spur or do these rarely break? Also, I would like to get a pinion for speed and one for torque, what sizes would you recommend? Im still unsure of how the gearing works, is there a good faq on it? Thirdly, in regards to temperature, how hot is too hot? Is it just if its too hot to ouch than its too hot? Thanks again |
09-18-2012, 03:24 AM | #9 | |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
As for pinions, I say start out with a 12t for crawling around. If you want faster then go to higher and higher pinions. But you lose torque and will increase heat. And as for temp, if you can't hold your finger on it for 5 seconds, it's too hot. Much over 170+ and permanent damage can be done to the motor. If you want exact temps then there are Rc specific temp guns that can be had. | |
09-18-2012, 11:15 AM | #10 |
I think 90\20 was stock, good bashing speed, ok crawling. With 48pitch gears the smallest you can go is 14t.pinion and that is only with a 96t spur.
09-18-2012, 11:31 AM | #11 |
96t spur is the largest 48p yes. But with some dremeling you can go smaller like I said to a 12t pinion. When higher voltage comes in you can gear down for control and still get higher top end. works well
Tekin 35t combo + 3s Lipo questions... - Similar Threads | ||||
Tekin fxr crawler combo 35t | REVOSOLDIER | Electronics | 3 | 12-13-2010 07:02 PM |
help with Tekin FXR 35t combo | XxRockStar199xX | Axial SCX-10 | 4 | 06-29-2010 03:01 PM |
need feedback on TEKIN 35T combo? | DAN8701 | Electronics | 10 | 09-16-2009 11:51 AM |
