01-10-2013, 12:39 AM | #1 |
Newbie Join Date: Nov 2012 Location: Kennewick
| Steering clearance
i was wondering if there was a way to make the WK have better steering I noticed the steering knuckles hit the C hubs on full lock turns is there any way to fix this to make it steer better? |
01-10-2013, 07:08 PM | #2 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
You can trim them for more steering or buy aluminum ones. Rc4wd makes high steer knuckles and rcp has some real nice ones.
01-10-2013, 08:05 PM | #3 |
| Re: Steering clearance
Thanks I was looking for something along those lines
01-13-2013, 02:38 PM | #4 |
Pebble Pounder Join Date: Nov 2006 Location: Canada
Im having the same problem too im in the works of tring to solve that problem. Ill post some pictures of what i did once im done
01-13-2013, 05:39 PM | #5 |
Zrazer i did some trimming on the steering. on the knuckles and the hubs. so the knuckle started like this and my hub like this cause i modded it abit already the hub after trimming and new counter sink screw in and the knuckle now after i was done and its put back together I found after testing it, it did turn better but it was binding still on the dog bone and the joint so now im looking in to getting Integy Universal Drive Shafts |
01-14-2013, 07:13 PM | #6 |
thats exactly what i was looking for im doing a budget build on my monster WK Crawler Where did u get the steering links for yours im using STRC aluminum set and its a little flimsy |
01-14-2013, 08:14 PM | #7 |
Im using 6/32 threaded rod and alum tube from the hobby shop to cover it with traxxas rod ends. all said and done it took me 30 minutes to do both sides with my drill press and a drum sanding bit. now im just waiting on my Universal Drive Shafts i ordered today from my lhs |
Steering clearance - Similar Threads | ||||
HR steering knuckles clearance issue. | motoxkfx | Axial Wraith | 0 | 06-25-2012 08:41 PM |
Bta or high clearance steering???? | donhd04 | Axial AX-10 Scorpion | 17 | 02-23-2012 08:46 AM |
High Clearance Steering Links | Sinastir | Axial AX-10 Scorpion | 35 | 11-23-2008 06:10 PM |
steering clearance? | Thaadius | Tamiya Clod Buster | 16 | 01-13-2006 06:30 PM |
