01-15-2013, 02:13 AM | #1 |
Newbie Join Date: Nov 2012 Location: Kennewick
| Help please
I have built a custom WK and used some off the shelf axial links with the links from the crawler conversion for upper links im using hot racing oiless air internal spring shock (not very good shocks) also using some Tmaxx shocks i had laying around because this is a heavy rig My problem is my chassis will lean to one side and move my axles out of square so when i hit the throttle it turns the opposite way not sure what i did wrong or how to fix so would someone please help me this is my first build |
01-15-2013, 10:11 AM | #2 |
Rock Stacker Join Date: Sep 2008 Location: cartersville Ga
| Re: Help please
It might help of you post a picture of the set up you running so people can have a visual, I'm also doing my first build so I'm not much help but I'm sure if people can see you set up it'd be easier to call out what wrong. Good luck
01-15-2013, 10:27 AM | #3 |
| Re: Help please
this is the only one i have right now the truck has been tore down for a chassis redesign the links will all be in the same place but the chassis will be shorter. [IMG][/IMG] |
01-15-2013, 10:28 AM | #4 |
| Re: Help please
I think you are talking about Torque Twist. You can cut it back buy adjusting your shocks and link locations. On an Axial, you can also swap out the ring/pinion axle gears to overdrive the front (or underdrive the rear, or both) and that will also help. Search Torque Twist (In titles) and you will find lot's of info and fixes. Last edited by johnnyh66; 01-15-2013 at 10:30 AM. |
01-15-2013, 10:33 AM | #5 |
| Re: Help please
yes but when i had the truck stock it didnt have this problem i am running the same set up on this but with longer links
01-15-2013, 10:57 AM | #6 |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
| Re: Help please
when you give it throttle the chassis rolls to one side? i think you need to start with stiffer springs. |
01-15-2013, 02:53 PM | #7 |
| Re: Help please
i did that but then it rolls really easy when turning but that might be fixed after my redesign
01-15-2013, 05:31 PM | #8 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: Help please
I could be wrong here, but the bottom links look to wide at the skid. Maybe triangulate them more? Also, that chassis looks HEAVY. Maybe cut out the un-needed material and lighten it up?
01-15-2013, 06:06 PM | #9 |
| Re: Help please
what do you mean too wide at the skid? thats the redesign and it is heavy whole truck ways around 8lbs with everything Last edited by Zrazer; 01-15-2013 at 06:10 PM. |
01-17-2013, 12:34 AM | #10 |
| Re: Help please
Eureka the chassis redesign fixed it sort of its lighter so i can use my maxx shocks without some spacers to stiffen it still torque steers a little but much better than before its about 2lbs lighter new problem my servo gears are gone need a new servo ill probably rebuild it and save it for a spare (Hitec 645mmg ultra torque) any suggestions for a better replacement |
