Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Wheely king crawler chassis-lower link mounts
Old 07-23-2014, 01:15 PM   #1
Default Wheely king crawler chassis-lower link mounts
Hello,
Is there any crawler chassis for wheely king axles from vendors or something to buy??
Also,are there better choices for lower link mounts?Now I have crawler king version and they have a lot of slop.What do you guys suggest?
DiKey is offline   Reply With Quote
Old 07-23-2014, 05:25 PM   #2
Default Re: Wheely king crawler chassis-lower link mounts
Here is some old cad fileshttp://offroader5.freeservers.com/templates.html
And an ancient thread.Scale Chassis Template For WK ?
lonleycreeper is offline   Reply With Quote
Old 07-23-2014, 06:55 PM   #3
Thanks for your reply.In thread you show me has a chassis from neweramodels,use stock transmission (a little high COG ) but looks good.However as you said,thread is old and neweramodels don't have it.
I have never used CAD and really will be difficult for a newbie.
I like the style of this chassis-build..
1st Attempt at a scratch built rig!
Old 07-24-2014, 09:40 AM   #4
Slop as in how? Side to side in the mounts?
killbucket is offline   Reply With Quote
Old 07-25-2014, 06:23 AM   #5
Best suggestion I can make for you is to hand draw something you like for the chassis, mock it up in cardboard, then cut it out in the material of your choice, I like poly cutting board from Walmart. I have done several chassis this way, it takes practice to get a perfect chassis but its fun.
Old 07-28-2014, 09:34 AM   #6
Sorry for late reply but had to make a video about the slop.
Here it is.
https://www.youtube.com/watch?v=0-kC...F2s78fBkmoyu8g
Do you believe that level3rc lower mounts will solve this problem?Are those more tight than stock plastic of crawler king?
Old 07-28-2014, 09:39 AM   #7
This is a good idea but I am not so good to handmade constructions,for that reason I search something ready for wk!
Old 08-02-2014, 03:06 PM   #8
In the band for now.
if you still have the plastic balls in the rod ends swap them out with some steel ones and that should take care of the slop.
lemonhead is offline   Reply With Quote
Old 08-03-2014, 09:47 AM   #9
I already run aluminum links with steel rod balls.I think the problem is the plastic lower link mounts.
Old 08-08-2014, 10:42 AM   #10
Like these?
Hot Racing HPI Electric Wheely King 1/12 RC Car upgrades and Hop-ups
billysnarf is offline   Reply With Quote
Old 08-21-2014, 05:41 PM   #11
Originally Posted by billysnarf View Post
Yes,I think level3rc has better mount with more holes to adjust the links.
Old 08-26-2014, 10:50 AM   #12
I have been using the HR ones with success.. dont forget the locktite..
Old 08-26-2014, 12:01 PM   #13
DNA made a cool WK chassis, But I'm not sure where if at all you can find only anymore.
KBrog is offline   Reply With Quote
Old 08-27-2014, 07:01 AM   #14
I want a mount with more holes like this.I don't know if I'll have the same problem with these.
I have seen two kind of chassis.
DNA RC Wheely King Chassis Kit , DNA200
SK Motion: DNA R/C Wheely King Pro Comp Chassis
The second is what I looking for but I don't know where can I buy one.
Wheely king crawler chassis-lower link mounts - Similar Threads
wheely king lower link and shock mounts iceman320 HPI Wheely King 3 03-27-2008 05:23 PM
Custom Wheely King Upper Link Mounts - In Stock @ TCScrawlers/The Crawler Store kevinlongisland Vendors Market 8 08-31-2007 05:27 PM
Wheely King Servo/Link mounts JasonInAugusta General Crawlers 1 01-06-2007 11:41 AM
