08-31-2016, 11:26 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Wind Gap
| Transfer case?
I've got a couple WK transmissions laying around aND a buddy of mine told me that I can convert them into transfer cases, is this true? If so, is there a write up or video on how to do it? Thank you in advance for any and all the help you can give me. Sent from my SM-N920V using Tapatalk |
09-01-2016, 05:57 AM | #2 |
| Re: Transfer case?
I lopped off the threaded section of the top shaft and enlarged the hole a bit. Works great! It's stuffed with RC4WD steel gears inside. Mine's mounted vertically as I needed something with some height. It's not very compact though - can see it tucked in the chassis below. |
Transfer case? - Similar Threads | ||||
Transfer case ? | 8ball ice | General Scale Talk | 3 | 09-15-2015 05:39 PM |
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case | Crawln Coles | Scale Accessories | 215 | 02-02-2009 03:31 PM |
