Thread: Anybody break Wheelie King stuff yet?
Old 02-24-2007, 10:23 AM   #1
Default Anybody break Wheelie King stuff yet?
Busted an axle today and the steering bellcrank a few days ago.
Pics:
http://nercc.net/index.php?topic=756.msg11428#new
fullmodtxt is offline   Reply With Quote
Old 02-24-2007, 10:27 AM   #2
I haven't broken a single thing on my stock one or my crawler wheely king. I abuse it pretty good.
You might want o check ebay I bough a front axle for 10.00 complete links steering everything, I also bout a rear for 35.00 complete + shipping of course
rockbender is offline   Reply With Quote
Old 02-24-2007, 08:06 PM   #3
I broke a servo saver and the front tie rod. I thought the servo saver broke pretty easily. I earned the tierod breakage tho. (driver error)
Dirttrackdemon is offline   Reply With Quote
Old 02-24-2007, 09:19 PM   #4
is that your grave diger? got any pics
cammok5 is offline   Reply With Quote
Old 02-25-2007, 10:04 PM   #5
Tech Addict
frdtrkguy's Avatar
Within 3 battery packs on my stock W-K I broke the steering bellcrank on the front axle and the servo saver. So I promptly tore it down and built it into a crawler! No breakage in its current form though!Click the image to open in full size.
frdtrkguy is offline   Reply With Quote
Old 03-12-2007, 02:41 AM   #6
JIA's Dad's Avatar
As the bell crank is the only thing I have broken on my WK rig. I have to say I believe it is the weakest link in the WK armor. It broke in the first 15 minutes I ran it. But I made a steel replacement and have had any other problems. TO break an axle is an acomplishment or improper assembly as I have bashed my rig in many ways without doing that. Maybe I just don't drive hard enough. YET
JIA's Dad is offline   Reply With Quote
Old 03-12-2007, 10:24 AM   #7
Yep, improper assembly busted the axle. Darn o-ring came out of the stub axle somewhere in the assembly process; never did turn up. I busted the bellcrank that pivots on the tranny after replacing the bellcrank on the axle with aluminum. Made a new servo mount to put the servo on the axle. I'm not crazy about how it looks, but it darn sure won't break! Pics are in the same link posted in the original post.
Old 03-12-2007, 12:05 PM   #8
first week i got mine i was jumping it in my frinds basement over a picnig table and landed on the front right tire and snapped the shock in half thenn the second run the other front one snapped and a few hours later i tried to go across a creek and went into deep and blew the esc
MaXX_CrAWlER7 is offline   Reply With Quote
Old 03-13-2007, 12:38 AM   #9
JIA's Dad's Avatar
Sound like you must be kin to WheelChair.
Old 03-13-2007, 06:24 PM   #10
broke the stock plastic upper link and shredded the gears in the rear axle
BlackJack is offline   Reply With Quote
Old 03-13-2007, 09:19 PM   #11
Broke a shock shaft while bashing with a tamiya mini cooper at work.
bsr241 is offline   Reply With Quote
Old 03-14-2007, 07:59 PM   #12
JIA's Dad's Avatar
Is that a Wheely King?
Old 03-20-2007, 12:02 AM   #13
WreckGar13's Avatar
I've broken a servo saver, tried to glue it til the new one ended up stripping the gears out of the servo. I then added a heavy duty Futaba servo and broke a bell crank. That is about it for the front end. My rear diff is making this horrible clicking noise when i mount my puller tires on it so I have to get some hardened gears. Other than that I love this truck, it take a beating and keeps on ticking!
WreckGar13 is offline   Reply With Quote
Old 03-22-2007, 02:18 AM   #14
JIA's Dad's Avatar
You may need to shim that rear end. That has been noted by others
Old 03-29-2007, 09:06 PM   #15
RivBlueNoma's Avatar
Are the WK's axles any tougher than the TLT axles? Ive only got 2 comps, and a few practice crawls on my new tlt rig and Im already sick of changing axle shafts. Looking for a better option over the tlt (no clods please )
RivBlueNoma is offline   Reply With Quote
Old 04-18-2007, 12:14 PM   #16
broke the front tie rod
the temp fix just some trash in the garage will hold,and its been holding sClick the image to open in full size.trong for quite a while
Kranberry is offline   Reply With Quote
