Thread: WK SW2 Build
Old 03-30-2007, 09:35 AM   #1
Default WK SW2 Build
I have been working on getting parts together for this build for a while. I have hit a snag however because I changed my mind on the lower link mount after mock up and ordering the links so I need shorter lower links to make the angle of the axles right and still at 12.5" I will be a little under 11.5" wide with these wheels. Here is a list of parts I am using and some pics...let me know what you think
Sw2 chassis
WK axles with Hardened gears in the diffs (Which gives you 5mm outputs)
Locked diffs with JB
R2 trans
WK shocks
Hypersion 3013
Mamba Max
Towerpro servos
RC4WD wheels
Moabs
M8 radio
Spectrum rec
Tlt upper link mount
Extreme Rc links High clearance
Tmaxx shafts 5mm output
Bushwacker body
Home made steering links
clarkrw3 is offline   Reply With Quote
Old 03-30-2007, 09:42 AM   #2
looks like a good start
brushlessnut is offline   Reply With Quote
Old 03-30-2007, 09:46 AM   #3
2006 2.2 National Champ
BENDER's Avatar
Pretty slick.
How do the upper link mounts on the axles feel? Any flex in the mount?
BENDER is offline   Reply With Quote
Old 03-30-2007, 09:55 AM   #4
Originally Posted by BENDER View Post
Pretty slick.
They are very solid... no flex at all. The WK mount has three screws holding it to the axle and the TLT mount has two screws holding it to the WK mount. No modding was needed for the TLT to match up with the WK mount
the four link in this set up actually limits travel compared to the stock 3 link, which I think is good in the application. Stock WK's have more travel than most want for a comp crawler anyway. With this set up and rotating the lower links 90deg you will end up with all 4 links the same length at 4.5" which is optimal...IMO
Old 03-30-2007, 11:51 AM   #5
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
How did the servo mount come out? Much trimming?
Josh
Harley is offline   Reply With Quote
Old 03-30-2007, 12:08 PM   #6
Some extra trimming around the pumpkin, as you can see the tab for the screw next to the wheel isn't far enough to screw into. If I do another one I would beef out the tabs that go down next to the pumpkin so they aren't so thin. Thanks for all your work on this. I would, however, buy one if someone made one that was more finished then mine. I am going to do rear steer so I will need anther one at some point.
Josh
Old 03-30-2007, 12:42 PM   #7
Throwing Grenades
Harley's Avatar
I will make those adjustments, when did you get a copy from me? I think I did extend the tab.
Would you be willing to cut out a new template and just hold the paper up to the one you made to see if it is an older version?
The more people who try the better, thanks.
Old 03-30-2007, 01:30 PM   #8
JIA's Dad's Avatar
Clark, The long shaft coming out of the tranny looks to go thru a carrier. If so where did you get it or what is it made from. Also does that long shaft come with the tranny. By the way looking good.
JIA's Dad is offline   Reply With Quote
Old 03-30-2007, 01:36 PM   #9
Those "carriers" are made by RC4WD and are just to adapt the 5mm shaft to 6mm so that you can easily run the Revo shafts. The long shaft comes standard with the tranny but you can get an optional short one if you want.
thanks for the kind words:-P
Old 03-31-2007, 02:06 PM   #10
Got new lower links coming from JP that sent out yesterday so hopefully I can have this thing running by the end of this week
Old 03-31-2007, 02:22 PM   #11
how wide are you with the rc4wd rims and tire together on the w/k axles
1beatjeep is offline   Reply With Quote
Old 03-31-2007, 05:10 PM   #12
Just under 11.5" wide as it sits.
Old 04-02-2007, 01:48 PM   #13
won't the steering linkage in the front hang up on the rocks. it angles outward, not to mention that they are plastic. do you have plans for steering linkages?
theTman is offline   Reply With Quote
Old 04-02-2007, 04:27 PM   #14
I do have some delrin links for the front, and yes rear steer would be nice and once someone makes a rear steer kit I will pick one up for sure.....waiting vendors!!!
Old 04-02-2007, 09:46 PM   #15
Throwing Grenades
Harley's Avatar
What kind of rear steer kit are you looking for?
Old 04-02-2007, 10:11 PM   #16
What you came up with is great!!! I just want someone to make it for me. I just don't have time for the fabrication right now, I just have too many things going on and I would love to get this thing buttoned up with machined parts.
Old 04-22-2007, 09:49 AM   #17
Ok...I am almost done. I still need to paint up the body and work on my rear steer. (which is allowed in PARC). The new template for the servo mount worked like a charm, and with 0.06 Al and tin snips in made drumal work much better. I also fabbed up a battery mount using the knuckle screw and two screws in the mount for the original steering link, which came out much better then expected and very solid.
My real question is this. I am going to be running 1500 cells in a brick pack on the axle, should I go with 6,7, or 8 cells? I am running a 3013 with Mamba Max. Also I am wonderering about final crawl ratio. The axles are 2.93:1 and my R2 is 30:1 so that gives about a 90:1 which I am sure is too high? I know that for supers you want it around 50-60:1 but am not sure what it should be for the 2.2 rigs. I have been searching but haven't found what I am looking for.
I will post pics soon it has come out great so far!!
Old 04-24-2007, 11:27 AM   #18
Here are the promised pictures.
Let me know what you think
This is my version of a battery mount and servo mount using the famous template that works great now!!Click the image to open in full size.
These are custom steering links the lower is made out of 8-32 rod and revo HD rod ends the top is a modifed link from Extreme RC delrin.
Old 04-24-2007, 03:49 PM   #19
I just ordered the battery packs from Holmes Hobbies for the rig and went with 2/3A Elite 1500 cells and 8 cell packs which should give me some punch. I also ordered a 13 tooth pinion which should give more wheel speed than the stock 8 tooth but still give me around a 60:1 crawl ratio. Once those things get here I will be ready to wheel with it and then rear steer set up... I am liking the way it is turning out. I have a bushwacker body for it and I think I am going to go with red and white.
Old 05-04-2007, 01:29 PM   #20
I have it running now Pretty impressed with the initial shack down. I might change from the 8 tooth pinion I am running now but it crawls crazy well now. I need a longer servo arm in the front to get a little more steering. I will be installing rear steer and mounting the body. I have a Bushwacker that I am painting red and white but need some more white paint. The battery pack works great and is very secure without the zip tie. John from Holmes Hobbies hooked me up with the sweet battery pack I think it came out great now have to see how it does in comps
Click the image to open in full size.Click the image to open in full size.
Now I just have to figure out how to keep my beads in my RC4WD beadlock wheels.
