Thread: taking the elect. out?
Old 04-15-2007, 12:23 PM   #1
Default taking the elect. out?
are they glued in or something? i was pulling them and itwas on there good. what could i use to get them to come off so i can put them in ballons. after there in the ballons should i use hot glue or modle glue to put them back?
cammok5 is offline   Reply With Quote
Old 04-15-2007, 12:25 PM   #2
Nlee111's Avatar
I use doubble sided tape.....
Nlee111 is offline   Reply With Quote
Old 04-15-2007, 12:29 PM   #3
what held them in before.
Old 04-15-2007, 12:30 PM   #4
Nlee111's Avatar
doubble stick tape.
Old 04-15-2007, 12:31 PM   #5
so just pull hard and thell come off?
Old 04-15-2007, 12:34 PM   #6
Nlee111's Avatar
Take a little screwdriver and jam it under there. then pry up gently.
Old 04-15-2007, 12:46 PM   #7
a dbl sided foam tape
Kranberry is offline   Reply With Quote
Old 04-15-2007, 01:11 PM   #8
thanks. there h20 prof now couse it been porrin nonstop since last night. going mudding wen it stops.
Old 04-15-2007, 01:12 PM   #9
Nlee111's Avatar
No problem
