04-19-2007, 11:55 PM | #1 |
Newbie Join Date: Feb 2007 Location: St George
| Revo A Arms to Extend
I have extended my WK using Revo A arms. They did need a little modification but they are working great and have giving me the articulation that I need.
04-20-2007, 12:07 AM | #2 |
Pebble Pounder Join Date: Jun 2006 Location: Massachusetts
any pictures??
04-20-2007, 12:47 AM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Useing Revo A arms for what exatly? As links?
04-20-2007, 08:04 AM | #4 |
Pebble Pounder Join Date: Jan 2007 Location: So.Cal
probably as an upper 3 link... i did this with my WK when i first got it but used MGT arms.. JOe |
04-20-2007, 09:28 AM | #5 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
I'm guess its the top link also... I pretty much did the same thing, but made it out of some flat stock alum. |
04-20-2007, 09:37 AM | #6 |
I was wondering if they would work. I have a Revo and was looking at it's suspension the other day and wondering if they'd fit. I thought of using the A-arm as the upper link and then try to get some of the pushrods or turnbuckles from the Revo as the lowers. Let's see some pics |
04-20-2007, 10:18 AM | #7 |
I'm using either the stock WK uppers (modified slightly) or MGT lower a-arms for my WK upper links.
04-22-2007, 10:21 PM | #8 |
Ya, I used the A arm for the upper link. I tried to make a 4 link but did not have enuff trianglelation so I went to a 3 link. I used threaded rod and steel brake line for the lower link. I found the brake line was the only thing that would hold up to the bashing. Pictures are forth comming. |
04-22-2007, 11:20 PM | #9 |
04-22-2007, 11:22 PM | #10 |
heres another Last edited by Jeneum; 04-22-2007 at 11:25 PM. |
04-23-2007, 06:03 AM | #11 |
Newbie Join Date: Jul 2006 Location: meadowlands
do you have any pics compared to the stock normal revo arm? it looks like you shaved the front down a bit. and they are the front uppers? and how long did you make the bottem links?
04-23-2007, 07:42 AM | #12 |
That has to be one of the rear lowers from a Revo. None of the other arms are concentric. The only thing I can see that would have to be trimmed is the spot on the end of the arm where you connect the suspension push rods...but it's only plastic right |
04-23-2007, 09:48 AM | #13 |
ya its only plastic, I found that I had to shave the sides and then cut it down to the length that I wanted. The lower links are about 5 1/2 inches long.
