04-21-2007, 12:49 PM | #1 |
Newbie Join Date: Apr 2007 Location: Sand Springs,OK
| revo shafts?
im looking for some good driveshafts so i can make some new links im thinking revo shafts i've scene them on other WK but i dont now what else i need to make them fit? thanks justin |
04-21-2007, 04:44 PM | #2 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
Nothing! you can take your shafts off at the ball and put the traxxas ones straight onto it. so you can use the collar that came on your wk, they fit perfectly and I believe you can use any length you wish so you wont need to cut them to fit, also the shafts for the e-savage look to be a pretty close match but i havent tried them so I'm not positive they'll fit
04-21-2007, 07:53 PM | #3 |
so all i need is these right http://www2.towerhobbies.com/cgi-bin...?&I=LXHFY1&P=Z |
04-21-2007, 09:56 PM | #4 |
Looks right to me, but you might want to get measurements w/ your new links so you know that they'll fit, if they're too long you could always try the stampede shafts
04-21-2007, 11:21 PM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
If space is limited, stock T-Maxx shafts work great and are indestructible as far as I can tell |
04-22-2007, 12:08 AM | #6 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Do the Revo yokes fit on the WK output and pinion shaft, or do you need to use the HPI yokes? I tested Jato and Stampede yokes and they are not the right size, but Maxx yokes fit. |
04-22-2007, 06:53 AM | #7 |
Quarry Creeper Join Date: Mar 2007 Location: Syracuse
Maxx yokes fit perfectly, you can still use that long grub screw that comes off the stok yokes. If anyone needs a picture Ill take one.
04-22-2007, 06:25 PM | #8 |
Yes...the Revo shafts fit like they were meant to go on these axles. The pinion input stub shaft is the same size as the Revo's mating hole at the end of the shaft. The cross pin holes line right up to the one's on the WK's output . |
04-22-2007, 06:35 PM | #9 |
thanks
