04-25-2007, 06:12 AM | #1 |
Newbie Join Date: Apr 2007 Location: Boston
| Drive shaft Help.
So i just got my WK 4x4 and i used the traxxs parts to stretch it out but only the lower links. For the rear i had to mount it to the hole that is farther back on the rear axle because when i went to the first hole the rear end it is far away so the drive shaft falls out. what has anyone done about this so that i can strech it out more? Thanks |
04-25-2007, 07:46 AM | #2 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Get new drive shafts. The Traxxas Revo's work as well as the Tmax with 6mm output flanges. You then will trim the shafts till they fit your rig. just make sure you know the wheel base you want to stay at before you chop the new drive shafts.
04-25-2007, 08:02 AM | #3 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
if you use maxx shafts... you can get 12.5" wheel base and you can leave the male end of the WK shafts (closest to the tranny) on.... so you only need the female maxx shafts.
04-25-2007, 09:01 AM | #4 |
That sounds great but are there people that have done this and dident upgrade the shafts? And what part number is everything i need. Thanks for the help everyone. |
04-25-2007, 09:40 AM | #5 |
these are all you need.... http://www2.towerhobbies.com/cgi-bin...?&I=LXSP55&P=M |
04-25-2007, 09:50 AM | #6 |
Thank you.
04-25-2007, 10:10 AM | #7 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
04-25-2007, 10:14 AM | #8 |
I just reused the WK yokes....
04-25-2007, 10:50 AM | #9 |
Hell's Gnome Join Date: Jun 2006 Location: I'm mean because you're stupid.
04-25-2007, 10:56 AM | #10 |
Quarry Creeper Join Date: Mar 2007 Location: AZ
The WK yokes are fine but the traxxas yokes are a bit bigger and probably stronger, both would probably hold up fine.
