Thread: rustler tranny gears..
Old 06-11-2007, 06:45 PM   #1
Default rustler tranny gears..
i know for the WK people are using 96/15,14,12 gears... i just got my old rustler back, and Iam goin to build a new chassis and use that tranny...
anyways... what are good gears to use on the rustler tranny?
guywithhat is offline   Reply With Quote
Old 06-11-2007, 06:46 PM   #2
rustler = stampede.....very common search
rockwerks is offline   Reply With Quote
Old 06-11-2007, 07:02 PM   #3
tried seach... didn't help... anyone else who has an anwser besides use the search button?
Old 06-11-2007, 07:12 PM   #4
search is your friend, there are over 100 threads about pede tranny gearing
here are a few looks like 12/87 is very common. of course that will depend on motor running, tire size, rig weight, etc.
How slow should it go?
Quark Procar 33A....getting HOT!!!
Which pinion on my pimp slap?
Pinions and Spurs
what setup?
Old 06-11-2007, 08:17 PM   #5
Default Stampede/Rustler gearing!
I use a 55T Lathe, 2/3a 8cell pack with my wk modded crawler. I run 13T pinion and 90T spur and can climb up walls from dead stop at the base. Runs just a bit fast than I can walk so wheelspeed is perfect as well. Good luck. 14.5" wheelbase as well.
scorpiuon1 is offline   Reply With Quote
Old 06-11-2007, 09:23 PM   #6
i figured out my problem.. i was just searching the WK section... thanks for the help.... got my rustler trans locked with an 1/8" nut....
