06-16-2007, 07:16 PM | #1 |
Rock Stacker Join Date: Apr 2007 Location: Goffstown
| Higher or Lower?
I built a chassis out of alum. so i'm not useing the stock chassis but i am useing the stock servo mount in the stock location up high.I seem to be having some linkage problems.It turns all the way right till the tires just barely rub the shock spring.But to the left it comes up short by about 1/4 inch.So i was thinking about putting the servo on the axle useing harley's template that way there would be less places for a problem with the linkage and more servo power to turn with.The problem is i run in a bit of water/mud and in winter the snow quite a bit so it gets wet around the front axle and i don't want to ruin my servo by getting it wet.Is there something to reliably waterproof the servo?Should i just keep it up high out of the wet?Is there a better way to mount the servo high and have good steering?Let me know how you run your's and what works good for you.
06-16-2007, 08:45 PM | #2 |
Quarry Creeper Join Date: Jan 2007 Location: Kansas City
06-16-2007, 08:45 PM | #3 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
Could be that your servo is not centered correctly. Your servo horn could also be off by a spline or two. If your using a transmitter with steering EPA's you could adjust it out. I am using the stock linkage still with a high torque servo in the back now since I swapped ends of the chassis. It all works fine. My radio has EPA's on the steering too.
06-16-2007, 08:56 PM | #4 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Could also be that the lower steering linkage from the chassis to the axle is now the wrong length too. Had that problem when I flipped my WK's chassis.
06-17-2007, 01:34 PM | #5 |
Thank you for all the feedback it was a great help.BJoe,Yup the lower steering linkage was a tad bit to long about 1/8 inch.All is good now i'm useing the futaba 3010 and it is working fine now.
