06-20-2007, 12:10 PM | #1 |
Newbie Join Date: Jun 2007 Location: Shelby Twp
| So Im getting a 4x4 WK...
So after spending 200 bucks, i have about another 200 with me right there, what do i get? new battery? i heard the one you get with it is fine for beginners, but a 4200 nimh will really give it some bite! new links? the plastic is strong, and the guy offered to dremel out the rear brace, but i think i will go with some aluminum links... which ones? Im not totally sure if i want it to be a full on crawler, as i dont have too many rocks near me, but tons of hills with steep sides along with some sand dunes... also, i know the WK is 1/12 scale, and most turn it into a small 1/10th, but can i make it into a 1/10 without going to full on scale mode? thanks in advance for any help |
06-20-2007, 12:22 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
1/10 body that the WB fits!
06-20-2007, 12:37 PM | #3 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
more cells gives you punch not the MAH so for more punch get more cells or higher discharge rate. more wheel speed go to lower turn motor and higher gearing and find a new 1/10th body wont be a crawler but will be fast! and more wheel speed | |
06-20-2007, 01:08 PM | #4 |
well, im not a total noob, so i thought more mah would only give me more runtime not more power. the salesguy said "bite" so i guess thats the way i described it... Im not looking for a full on crawler, more like a truck that is fairly speedy, but has the torque to power up huge dunes (i can go to the sleeping bear dunes which has dunes that are very steep and very tall ) and not to diss the WK, but i already see a TXT in the future |
06-20-2007, 06:45 PM | #5 |
Rock Stacker Join Date: Jun 2007 Location: Pitt Meadows
if your looking to just go sand duning the wk stock would work fine although you might want to extend the wb and put the battery over the front wheels but i think it would be great fun at the dunes just keepin' 'er stock . and yes I would recomend a better battery. good luck! |
