06-25-2007, 10:47 PM | #1 |
Newbie Join Date: Jun 2007 Location: cedar hill
| 55t question
can you use a 55t lathe motor in the stock setup.in more detail can i put a 55t lathe motor in my wheely king right out of the box without any modifications.thanks |
06-25-2007, 10:51 PM | #2 |
Yes, you can put in a 55t lathe motor into a stock wk. You will likely have to solder the wires to the motor. The motor will need a gear put on it. Set the mesh of the gears like they describe in the wk manual and you will be good to go!
06-25-2007, 10:59 PM | #3 |
thanks yea im a desent with a sodering iron but i havent bout my wk yet and i just wanted to know what i should go ahead and buy with it.cause im looking into making it a capable crawler and just wanted to know if that motor would fit the stock set up for now.but i see in my future a nice tuber with extended linkages and drivetrain narrowed moab tiers and some beadlocks.
06-25-2007, 11:10 PM | #4 |
I wanna be Dave Join Date: Jun 2007 Location: Arlington wa
yup i put a 65 turn on mine when i bought mine.. the day i got my WK i got motor,gears,links,beadlocks,moabs,and hacked up the body...lol but i had a chonk of money to blow.. |
06-25-2007, 11:29 PM | #5 |
yea if you dont mind me asking about how much did all that cost.casue all that is right up my ally and in detail what did you buy
06-25-2007, 11:52 PM | #6 |
well here goes off the top of my head 65 turn motor 20$ gear 96 and 15 pinion 7$ traxass 102mm links x4 25$ axial beadlocks x4 60$ 4x proline moabs 40$ and some misc. bolts and 3mm nuts 3-15$ hot glued the diffs and mine went great then i turned it into |
06-25-2007, 11:56 PM | #7 |
btw... my wk doesnt look like that at all nemore... lol look at the thread called "PROJECT NO NAME" thats what it is now..
06-26-2007, 11:53 AM | #8 |
yea i looked at your project this morning and thats anice tuber you got there.have you got it set up right yet or do you still have the twist problem?
06-26-2007, 04:27 PM | #9 |
Quarry Creeper Join Date: Jun 2007 Location: santa rosa
what was the wheel base before u made it a tuber and u used the 102 mm links |
06-26-2007, 10:46 PM | #10 |
not as bad... kreepy helped me out today and we found the problem so im gonna start there... but with the 102 links it was 10.5 inches i beleive
06-29-2007, 12:35 AM | #11 |
Quarry Creeper Join Date: Mar 2007 Location: 530
Blakeski when your WK was 10.5 did you have to modify the drive shafts or steering? I really like how it looked with the red rods.
