06-28-2007, 03:37 AM | #1 |
Rock Stacker Join Date: Jun 2007 Location: NOR CAL
| ESC getting HOT!
I just bought a new wking today, put deans plugs on the second it came out of the box, because I didn't want to wait 6hrs for the included charger and crap battery. This thing is great! But I noticed the ESC is getting 280f+ when under strain, I assume this isnt good... Is that normal for this truck? I smell somthing that is almost burning... Using GP3300 raido shack batts and removed the rear brace out of the box, thats all so far, 1st crawler, have a MM5700 pede and warhead nitro MT |
06-28-2007, 03:41 AM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
It's normal, that esc is a really cheap crappy unit. I'd recommend a ESC upgrade right away. Hpi never designed the wheely as a crawler. The esc can't take the slow throttle inputs.
06-28-2007, 03:52 AM | #3 |
| whats the suggested replacement? |
06-28-2007, 06:13 AM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: land of make believe
look thru some threads on here and you will find some names of decent ones...LRP, Tekin, Mamba, Novak...you could also go to your LHS and ask for a decent one...i think i started with a duratrax esc...metal heatsink is a good place to start as the jolt(stock) is plastic if i remember correctly. maybe it just looks plasticky...
06-28-2007, 06:19 AM | #5 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
I put some aluminum fins on my stock ESC and used it until my Mamba Max/crawler master came in. The ESC will (fortunately) shut down if it gets too hot. Unfortunately, mine did that a lot before I put the fins on it.
06-28-2007, 12:14 PM | #6 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
I just mounted a small computer fan just above my ESC to keep it cool: It runs off a 9 volt termporarily mounted on the front axle. With this running, my ESC only get warms during slow crawling - even in hot temps. Its a cheap, quick fix until you either get a new ESC or run a 55t motor. |
06-28-2007, 03:33 PM | #7 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
The problem is that your still running the 27 turn motor. If your going to crawl, buy a crawler motor and the ESC will be fine then.
06-28-2007, 05:23 PM | #8 |
| Have you verified this through personal experience? Unless you have, I have to express some skepticism - honestly, the ESC that come with the truck just sucks. But then, what do you expect, getting a pretty tough, pretty trick truck for under $200 with running gear? - oh well. I guess I might just be old. I remember paying $329 for a two channel AM radio...
06-28-2007, 10:25 PM | #9 | |
06-29-2007, 12:09 AM | #10 |
Quarry Creeper Join Date: Mar 2007 Location: 530
Did you have to make any modifications to run that gear setup? And how do you like it?
06-29-2007, 12:23 AM | #11 |
It is slow and I like it that way. You can go 96T on the spur, but the gear cover will need to be clearanced inside. I dont run the cover on mine. If more speed is needed you can go up on the pinion, or use a different motor wind.
06-29-2007, 12:38 AM | #12 |
Thanks for the quick reply.
06-29-2007, 01:45 AM | #13 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
I am running the stock wk esc with a 55t lathe r2 tranny with a 8 tooth pin. in a 1.9 scaler and the esc works perfectly fine
06-29-2007, 03:46 AM | #14 | |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Unless you got a bad unit it will work fine for crawling! Just dont expect to crawl around at a snails pace with no cooling air running the stock motor. My 2cents... | |
06-29-2007, 08:00 AM | #15 |
Yea, I mean, for the record, my stock ESC would shut down before I put fins on it, even with 96/15 gearing. After the fins, I didn't have any problems.
06-29-2007, 08:22 AM | #16 |
Pebble Pounder Join Date: Jun 2007 Location: nor cal
mine does the same thing, crawl for about 10 min then it shuts down. I put a 35T lathe in it for now and that gives me more time, from what I have read in these threads if you go with a 55T or 65T you will have no more issues with it overheating.
