| | #1 |
| Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| Are there any options for gears for the tranny other than stock? I got a little ham handed on the throttle this morning when it was bound up and knocked most of the teeth off two of the gears in the tranny, which amuses me to no end considering I do *not* have the slipper locked. Of course, if there's someone out there that thinks I should just scrap the wk tranny and get something else, I'd be open to suggestions on that too. Eventually either this tranny, or what I replace it with will land in the tuber I'm going to build once I have my hands on another working crawler (read, when my AX-10 gets here). |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
| I dont think there are any hopup replacements yet. I would just upgrade tp an r2 because of the size. Put the r2 in a tuber low and you can put in seats and the r2 might look like some sort of transfer case. |
| | #3 |
| Rock Crawler Join Date: May 2007 Location: Franklin ME
| I love my XX-T tranny. Tiny, strong, and it comes stock with sliders. |
| | #4 |
| Quarry Creeper Join Date: Feb 2005 Location: Vancouver Island B.C.
| I would assume you are running a brushless setup, in which case i would stay away from the R2. The associated b3/4 trannies are beefy and small. |
| | #5 |
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| the R2 gets trashed pretty quick with a 28 or 30mm outrunner. If you are running a 22mm motor you are pretty safe. The r2 is nice though, if you are running the mamba max you could add a lot of punch control to reduce the hard knocks on the tranny from hamfisted throttle squeezing. |
| | #7 |
| Didnt think of that part. Sorry.Are the gears really weak or something? Or is it geared too low for that much power? I need something cheap and usuable as a transfer case would the xxt tranney be could and where can I get it or asseble it? |
| | #8 |
| You can get them on ebay for fairly cheap. If you get one that came with dog bones you will need part number: LOSA3095 these are the slider outputs. They are $3-4 for a set so its not a big deal. I'm running t-maxx shafts. |
| Thread Tools | |
| Display Modes | |
