Thread: Gears
Old 07-30-2007, 12:04 PM   #1
Default Gears
Hey everyone i just got my stuff in from TH and i bought everything HPI did for their WK build but i got the 93T instead of the 96T. I put them on the tranny but they do not touch at all.
RcGuY07 is offline   Reply With Quote
Old 07-30-2007, 12:11 PM   #2
In between.
SACCO's Avatar
loosen the motor screws and move it closer? What pinion did you get?
SACCO is offline   Reply With Quote
Old 07-30-2007, 12:18 PM   #3
um i think it is a close as it can be but i will try, i got a 48p 15t #1015
Old 07-30-2007, 12:41 PM   #4
i did the exact same thing. but dont waste your time doing what i did. just get the other gear.
jdking is offline   Reply With Quote
Old 07-30-2007, 01:38 PM   #5
In between.
SACCO's Avatar
then you prolly got to elongate the adjustment hole in the motor mount. Just put the stock pinion on there til you get the 96t spur if you dont wanna do that.
