| | #1 |
| Quarry Creeper Join Date: Jun 2007 Location: Sacramento
| What kind of run time should I expect with a 65T motor and the stock HPI 6 cell battery and 15/96 gears? I also have a couple 7 cell 1800's from my brother's old buggy. With the stock motor, the ESC keeps over heating (too much amps I guess). Does anyone think i can still use the 7 cells with a 65T without overheating? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: May 2006 Location: USA
| with stock gearing and stock battery with a 65t motor i would guess around 30 minutes of run time. 7 cell will be fine with that motor, just make sure the ESC can handle it. Last edited by BrandonW; 08-03-2007 at 01:02 PM. Reason: spelling |
| | #3 |
| I guess the only way to tell is to drive it and see if it overheats. I've heard of some guys getting 1-2 hours of run time, is that right? how? I can only guess with a 4200 NiMH or something... |
| | #4 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| I got close to an hour out of some 3000mah nimh batts I have. 55t motor and same gearing as you. The esc would start shutting off after 25 min or so. I would just let it cool for a few seconds and it would run for a couple minutes. |
| | #5 |
| Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
| Must be something wrong with you guys. I can get 45-50 minutes, 15/96 gears, 65t lathe, on stock battery. I have never had my ESC over heat, and I have run in some high 90 degree weather. |
| | #6 |
| If I study each line carefully and take my time I could stretch it out pretty far. |
| Thread Tools | |
| Display Modes | |
