08-18-2007, 08:09 AM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| 60/40 link lengths?
I'm at 53/48 and wanna go steeper, so I was gonna try a 60%/40% link ratio,60 rear40 front. Has anyone set up a WK chassis in this manner? What were the link lengths? I'm not totally bass ackwards and confusing link length with weight distribution am I ???? Please correct me if I'm way off base here! i just want to build! Last edited by solomon7; 08-18-2007 at 09:34 PM. |
08-19-2007, 12:45 AM | #2 | |
Rock Stacker Join Date: Jun 2007 Location: Virginia Beach
Front upper: 92mm Front lower: 97mm Rear upper: 150mm Rear lower: 158mm This should get you pretty darn close. One thing to remeber though is that the front axle will be brought in more under the chassis. You may have clearance issues with the front axle hitting the chassis during articulation, especially if you have an axle mounted servo. Another issus will be driveshaft length. You may be able to use the stock front drive shaft and perhaps the Traxxas #4951 drive shaft set for the rear. There may be other issues you run into as well, but I say GO FOR IT! Document your build and let us know how it turns out. | |
