08-22-2007, 12:25 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| spur wobbly
I noticed kin of a rythmic sound coming form the center are, pulled the gear cover off and the spur is wobbling. The 90 tooth did it and I went to a 93 tooth. It was fine for a while but now it's wobbling too. I'm a bit in the dark here. What's going on and is there a way to fix? I cheked the mesh and it's fine FWIW
08-22-2007, 04:51 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Midway
Are all the screws holding it on totally tight. I had a problem like that and found I had stripped a screw hole out.
08-22-2007, 05:51 PM | #3 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
My WK tranny has a bent input shaft! wobble wobble wobble wobble wobble wobble wobble |
08-23-2007, 01:23 AM | #4 |
Quarry Creeper Join Date: Jul 2007 Location: Holland,OH
I had to tweek mine when I changed out the pinion gear. got a loittle bent out of shape somehow. All is good now.
08-23-2007, 03:08 AM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
The original Wheely gears are soft nylon. Under high stress the gear will deform and fold. New HPI gears are carbon fiber (much stiffer). But, since you got a new gear this probably doesn't apply.
08-23-2007, 12:13 PM | #6 |
08-23-2007, 08:27 PM | #7 |
Mine wobbles bad with a brand new Kimbrough spur....wobbled with stocker too! Need to look at my shaft asap. |
08-23-2007, 09:55 PM | #8 |
HPI said it is probably the adapter on the shaft tht connects the spur. They said sometimes the pin groove isn't perfectly symmetrical.
08-25-2007, 02:49 AM | #9 |
08-25-2007, 04:46 AM | #10 |
Couple hits with a dremel cut off disk should help.
