08-31-2007, 07:40 PM | #1 |
Newbie Join Date: Jun 2007 Location: Wappinger Falls
| My Wk Trail/crawler STRETCHED WK 11.5 TRAXXAS ROD ENDS FOR UPPER/LOWER LINKS STOCK WHEELS/ TIRES WITH CUSTOM WEIGHTS (NUTS/BOLTS) STOCK ELECTRICS EXCEPT FOR MOTOR INTEGY 35T, 96TH SPUR, 15TH PINION AXIAL BEADLOCK WHEELS/PROLINE MOABS WITH STICK ON WEIGHTS(6OZ) CUSTOM WEIGHTS ON FRONT BUMBPER (4OZ FISHING WTS X2) SHOCK MOUNTS ROTATED 90DEGREES IN *WAITING FOR FRONT SERVO MOUNT FROM RCGUY*. MIGHT WATERPROOF ELECTRICS. "RUNS WELL WITH GOOD ARTICULATON ON TRAILS AND OVER ROCKS. SWAP THE TIRES AROUND DEPENDING ON THE TERRAIN." CUSTOM WHEEL WEIGHTS ON STOCK WHEEL/TIRE. Last edited by ksean6969; 08-31-2007 at 07:52 PM. |
09-01-2007, 08:08 AM | #2 |
Newbie Join Date: May 2007 Location: BELTON,MO
Looks good. I'm just a newb but I do have to wonder about that 8oz of weight that high up. What traxxas links did you use to get the 11.5" wheelbase?
09-01-2007, 11:41 AM | #3 |
dont remember off the top of my head, but if you check some other posts you'll find the part number.
09-01-2007, 11:56 AM | #4 |
Rock Stacker Join Date: Aug 2007 Location: shoreline
how do u rotate the things that the bottom links and shocks are mounted on, my wk has little groves on the top and bottom that won't let me rotate those
09-01-2007, 01:08 PM | #5 |
