09-19-2007, 07:06 AM | #1 |
Rock Stacker Join Date: Jul 2007 Location: Pollock Pines, Nor Cal. Close to the 'Con!
| Wobbling spur gear....Need alum. gear hub!
Attn. Vendors!!! I'm sure there are more of you out there that have a spur gear hub that came from the factory out of whack, and causes the spur gear to wobble. Is there a vendor already making an aftermarket gear hub for the WK tranny? Or, what are you guys doing to correct it? John. |
09-19-2007, 08:57 AM | #2 |
Pebble Pounder Join Date: Jul 2007 Location: jonesboro
???? i havent had that problem,yet.
09-19-2007, 10:36 AM | #3 |
Newbie Join Date: Jun 2007 Location: Concord
I hear ya'...my spur gear wobbles around like crazy!!
09-19-2007, 10:36 AM | #4 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
Mine wobbled a bit when I first got it because the screws were loose. Tightened 'em down and it went right into place. Either that, or pull the hub off and check for any little pieces of extra plastic in there.
09-19-2007, 10:39 AM | #5 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| you can add washers under the bolts also to spread the load across the spur gear
09-19-2007, 10:49 AM | #6 |
RCC Addict Join Date: May 2006 Location: USA
crank down the screws and or use spacers like previously stated it will work fine after that.
09-20-2007, 05:24 AM | #7 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
When making adapter please put the traxxas bolt pattern on it as well as the stock one. |
09-20-2007, 02:58 PM | #8 |
09-22-2007, 11:03 PM | #9 |
Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
Mine still wobbles after washers and tweaking, switched to a 32 pitch for strength and no problems since plus I can gear down lower w/ a 72 tooth spur w/o clearance issues
09-23-2007, 12:27 PM | #10 |
Pebble Pounder Join Date: Apr 2007 Location: parked in a handicap spot
hpi has some alum adapters made.. they are for the rs4 electric series cars. they have actually had these out for years.they should fit perfect on the stock wk top shaft. give em a call. |
09-24-2007, 07:12 AM | #11 |
09-24-2007, 08:26 AM | #12 |
| part # 72039 Prevents spur gear wobble and keeps the gear mesh true. |
09-24-2007, 08:53 AM | #13 |
09-24-2007, 09:46 AM | #14 |
Quarry Creeper Join Date: Aug 2005 Location: Spokane
I searched 4 sites to include HPI and could not find one.
09-24-2007, 09:53 AM | #15 |
09-24-2007, 09:55 AM | #16 |
24$...............I havent had a problem yet. Thats almost enough for an AX-10 tranny or enough to set up the pede tranny I have back in LV. I found it now after some further searching under the discontinued Super RS4 parts.
09-24-2007, 10:38 PM | #17 |
if you are looking for one look under hpi rs4 pro2, sport, pro.. they should have some at tower hobbies..
09-24-2007, 10:46 PM | #18 |
Searched the above part number and it is not found at tower.
09-25-2007, 07:13 AM | #19 |
09-25-2007, 07:30 AM | #20 |
| Not that I looked much for them specifically, but where did you find 32 pitch spurs to fit the WK trans? What's the diameter of the 72t spur you have?
