Thread: WK trail truck
Old 12-15-2007, 05:52 PM   #1
Default WK trail truck
kiwi trasher is offline   Reply With Quote
Old 12-15-2007, 05:59 PM   #2
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 12-15-2007, 06:09 PM   #3
any specs? looks nice.
bigblazerboy is offline   Reply With Quote
Old 12-15-2007, 06:34 PM   #4
its just got all the normal stuff rooster crawler ecu,70t motor.its just a hacked up wk chassis cos i got withdral from not play with a crawler while i build my other truck.
it gets 90 degree flex just not with that body cos i dont wana hack it up because i like scale looking trucks
Old 12-15-2007, 07:10 PM   #5
that is nice,did you make the upper/lower links?
pickup1 is offline   Reply With Quote
Old 12-15-2007, 08:04 PM   #6
It looks pretty good. I would try and get the COG down a little, and mount the battery lower.
Shaun is offline   Reply With Quote
Old 12-15-2007, 08:31 PM   #7
Thats awesome. That body looks nice.
LST022752 is offline   Reply With Quote
Old 12-15-2007, 09:31 PM   #8
Hey thats nice...did you mod the WK chassis and cut the bottom part off? I was just thinking of doing that...I was trying figure out a way to mount the lower links to the axle mount that also holds the shocks...do you have more pics on how you attached it?
Sasquatchbagger is offline   Reply With Quote
Old 12-15-2007, 09:50 PM   #9
as it is it goes everywhere my mates scopion dose,the motor is set up higher cos the bottom of chassis is cut off
Old 12-15-2007, 09:57 PM   #10
yea i cut the bottom off,hacked up the sides and cut the back off which is now the front.i put more pics up soon
Old 12-16-2007, 04:39 AM   #11
Looks nice, but I'd put the battery on the front upper links.
Old 12-16-2007, 12:50 PM   #12
MSB
it looks good, but doesn't moving the motor/tranny up to clock it seem counterintuitive? personally i would have just left it in the stock position to keep the driveline angles better
MSB is online now   Reply With Quote
Old 12-16-2007, 04:22 PM   #13
na cant put the battery on upper arms cos its hits the chassis when it is flexing,but i do have to sort something out which will be a better setup.
the speed it goes im not to worried bout the angles of the drive shafts,me and my mate have both done this to our wk and havent had any problems.they have been made more for hill climbing than rock crawling
Old 12-16-2007, 04:25 PM   #14
from cutting the bottom of the chassis of it has got over an inch more ground clearance now,befor it would just get hung up on everything...
