Thread: wk axles/maxx shafts/ ax10 tranny?
Old 12-19-2007, 12:17 AM   #1
Sir Limps Alot
djjiz's Avatar
Exclamation wk axles/maxx shafts/ ax10 tranny?
I'm in the process of building a tuber and I'm having a little truble fitting the parts above. Anyone run a similar setup already? I've searched but I'm brouse with my phone so 40 minutes later I figured asking you guys.
Thanks
Chad
djjiz is offline   Reply With Quote
Old 12-19-2007, 12:28 AM   #2
What do you need to know? I'm not sure anyone is running a AX10 tranny, but its pretty similar to any other tranny.
Shaun is offline   Reply With Quote
Old 12-19-2007, 12:42 AM   #3
Sir Limps Alot
djjiz's Avatar
The tranny output needs a litle a little grinding to fit a maxx shaft, that's not a problem. My problem is with spur gear clearence.
Old 12-19-2007, 12:44 AM   #4
Oh. Have to wait for another person on that. I don't know much about the axle tranny.
Old 12-19-2007, 09:49 AM   #5
I used pede shafts and steel yokes to set up my WK axles with an ax-10 trans. I drilled out the yokes to 6 mm and tapped one screw hole on the yoke to 4mm x 0.7 and used the stock WK yoke pins, and on the trans I ground off the thin end step, otherwise the steel pede yokes work perfectly on the axial unit. I haven't had any trouble with it, most of the tlt guys use pede shafts without any problems. Good luck.
chrisjlittle is offline   Reply With Quote
Old 12-19-2007, 09:51 AM   #6
The maxx and wk axles and transmissions are 6mm, the axial/tlt/pede stuff is all 5mm. Grinding the tranny output will make it fit worse, not better.
Old 12-19-2007, 10:11 AM   #7
Sir Limps Alot
djjiz's Avatar
Fit worse if I grind? I was a little tired working on this stuff last night. I'd better double check my work.
I know I need the pinion shaft from axials to make the pede shafts work. This parts list is getting out of hand lol
Old 12-19-2007, 11:04 AM   #8
Mriswith's Avatar
Look around for RC4D adapters. They've got a 5 to 6mm converter . Slap that on the Axial trans and you can run the bigger shafts or get MT hardened ring and pinion. The pinion is 5mm.
Mriswith is offline   Reply With Quote
Old 12-19-2007, 10:27 PM   #9
I figured that out right after I dropped a wad on steel pede yokes. I feel kinda stupid about that, seeing as I still have maxx shafts sitting around, unused. Definitely the easiest way to go, and the price is reasonable.
Old 12-19-2007, 11:14 PM   #10
hitman46mod's Avatar
I'm intrested in this too. I have a 2.2 comp tuber in the mix I was also going to use an ax10 tranny, high lift axles, and E maxx shafts. I thought every thing was 5mm. I was going to use the steel traxxas yokes with the set screws. That way the E maxx shafts could be used. Or should I just drill the pinion and trans output shafts to take the pin in the 6 mm traxxas long shafts.
hitman46mod is offline   Reply With Quote
Old 12-19-2007, 11:15 PM   #11
i had the same problem with my spur hittin the drive shaft. i just put a 84t spur on it and had the extra clearance.
hardkorh is offline   Reply With Quote
Old 12-20-2007, 12:13 AM   #12
I drilled a hole through the output shaft and put a screw through it to connect them. seems to hold better than 2 set screws.
juststartin is offline   Reply With Quote
