| | #1 |
| Quarry Creeper Join Date: Aug 2006 Location: Farmerville
| Okay, I have a sw3 chassis, r2d tranny, wheely king axles, and xtreme rc 50/50 high clearance links. What lenght punisher drive shafts do I need and do they need to be 5mm or 6mm??? Any help would be highly appreciated. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2005 Location: West Omaha
| I believe the r2 ane wd need 5mm not sure though, measure them. Also put it together and measure to see how lng of a shaft you need. |
| | #3 |
| Pebble Pounder Join Date: Jun 2007 Location: Las Vegas
| The r2d has a 5mm shaft while the wheely king is 6mm. If you wanted to, you could upgrade to hpi's hardened ring and pinion for the MT2 and that would change you to 5mm on the axle. As for length, just measure from the output on the tranny to the input on the axle and then buy the shaft that most closely matches that length. |
| | #4 |
| I don't have the links here yet and I was trying to get my shafts ordered. I have a different setup right now and my shafts are different. I was just trying to see if someone had the same setup??? |
| Thread Tools | |
| Display Modes | |
