01-09-2008, 01:44 PM | #1 |
Newbie Join Date: Dec 2007 Location: Roswell
| moved the servo to the front axle
these are some pics of my wk. I have taken the wk steering links off and made my own out of all thread and alum tubing since these pics. I am still adding my goal is to win a comp with this truck and once I have done that then I will make my own from scratch!! hope you like! inside the truck 65t lathe integy motor 118 mm bottom links 100 mm top links 96t spur gear 15t pinion locked diffs front & rear straight rear axle adapters [[/IMG] Last edited by IcemanXtc; 01-11-2008 at 02:57 PM. Reason: changed the pics |
01-09-2008, 01:46 PM | #2 |
Pebble Pounder Join Date: Dec 2007 Location: NIPOMO!!!
Looks like a good build. what rims are those?
01-09-2008, 01:49 PM | #3 |
| Rims
axial bedlocks 2.2 tires are proline mashers |
01-09-2008, 02:39 PM | #4 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
01-09-2008, 02:54 PM | #5 |
| wheel specs
axil rockster SPECS: Width: 1.4" (36mm) Beadlock Diameter: 2.2" (55.5mm) Hex Size: 0.47" (12mm) pro line mud thrashers SPECS: Inner bead diameter: 56mm (2.2") Total outer diameter: 124mm (4.9") Inner bead width: 50mm (2") Total outer width: 62mm (2.4") hope this helps!!!! |
01-09-2008, 04:58 PM | #6 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
loooks good how do you like the 65t in that thing
01-09-2008, 05:06 PM | #7 | |
Towerhobbies has those listed as 4.9" ... but the M3 version as 4.72 ... which is why I asked. Last edited by Locked Up; 01-09-2008 at 05:14 PM. | |
01-09-2008, 09:27 PM | #8 |
| 65t motor
the motor works great i have the stock esc on for now and that thing stinks but when i installed the new motor that helped alot with the braking. i cant wait till i get the rooster this thing will be able to hang on a verticle slope.
01-09-2008, 09:30 PM | #9 |
im not sure i understand.
01-10-2008, 07:36 AM | #10 |
Newbie Join Date: Dec 2007 Location: Heltonville
What he wants to know is the actual size of those tires on those wheels. Just like with real truck tires, most tires won't measure the same when mounted on wheels as they do in the manufactors specs. If you put those tires on really narrow wheels, they would be bigger diameter than if you mount them on really wide wheels, and they probably wouldn't match the manufactors specs in either case.
01-10-2008, 01:22 PM | #11 | |
if this isnt right just explain to me how it needs to be done and I will do that. Again sorry for the Ignorance but I bought this truck stock out of the box two weeks ago and this is the first time I have ever had a r/c! | |
