Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Try'n Tuben
Old 09-22-2008, 06:11 PM   #1
Default Try'n Tuben
Here's my next project. Tube chassis 1/4" brake line, silver solder, & stress. I have trouble with patience. The axles are shortend for cvd shafts.
Need to figure out my links now.
Last edited by Reflection; 09-25-2008 at 07:16 PM. Reason: fixed so it's easier to read
MAKKEM is offline   Reply With Quote
Old 09-23-2008, 05:29 PM   #2
Bart bender's Avatar
That looks good. You're to hard on yourself. For a handicap, it looks great
Bart bender is offline   Reply With Quote
Old 09-25-2008, 07:17 PM   #3
TEAM MODERATOR
Reflection's Avatar
I edited your post so it's easier to read.
Looks like a cool build. I like the low profile cab section.
Reflection is offline   Reply With Quote
Old 10-24-2008, 06:17 PM   #4
You gonna get those pics you took posted? This rig is lookin really good now.
Old 10-28-2008, 06:06 PM   #5
Got my links all done. Rear shocks are where I want them. The front I'm having some trouble the tire rubs hard when I flex it. I have the drive shafts in now not pictured yet. One servo mount done also. The big question is where to put the electronics.
I'll try to get the other pictures when I can
Old 10-28-2008, 07:05 PM   #6
You also narrowed the axles and now running short CV's. Also cut a custom trany shaft to get the drive shafts to line up better with the suspension linkage.
Old 01-19-2009, 06:59 PM   #7
finally have it besides some minor tweeking.
Ran it at Barts gtg last week end scratched it up a little and gave it caracter.
Changed from a traxxes remote to a mx3 no more glitching and the receiver is much smaller. Also took out my rooster replaced with fxr mostly for size. Very happy with the results.
Old 01-19-2009, 08:43 PM   #8
looks graet good job
eclipse9 is offline   Reply With Quote
Old 01-20-2009, 03:46 PM   #9
Oh yah she's a runner. Made one climb I couldn't get. Now I am going to chop down my width like Raptorman said I should and clean house this summer MAKKEM's gonna do something about that articulation too. Just haven't figured out what. Maybe limit the travel?
Old 01-29-2009, 07:09 AM   #10
Default chassie q's
nice chassie, what kind of metal is the brake line and did you say you soldered it together? what kind of solder did ya use?
krazikev is offline   Reply With Quote
Old 01-29-2009, 03:16 PM   #11
Regular old steel brake line with Saftey Silv 56 silver solder. There is a TON of info on bulding tubers, just search around
Old 02-02-2009, 06:14 AM   #12
Is a mini torch needed ???
Rods is offline   Reply With Quote
Old 02-02-2009, 07:21 AM   #13
Just a butane torch works. I prefer MAP gas.
