Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Diff issues
Old 11-14-2008, 03:38 AM   #1
Default Diff issues
I have some major diff problems and need to know the best way to get in touch with Kyosho to order new ones. I just need their e-mail address or phone number. Or if somone has some Twin Force diffs complete that they would be willing to get rid of just pm me. Thanks in advance!
ThanX,
Krystopher
Toph is offline   Reply With Quote
Old 11-14-2008, 02:47 PM   #2
Bart bender's Avatar
Watcha need? I have a lot of stock diffs since I only run CDW spools.
Bart bender is offline   Reply With Quote
Old 11-15-2008, 08:47 AM   #3
I need the diff housing with spider gears, drive cups, and the bearings.
Old 11-15-2008, 11:34 AM   #4
Need diff for kyosho mad/twin force. I think it's the hellfire that fits. That's what I got in mine. I would be interested in what you are doing with the hex/stub issue. I'll be keeping an eye on you as well as finding out about turning those savages down.
MojaveMonster is offline   Reply With Quote
Old 11-15-2008, 11:56 AM   #5
Would you know where I can get the Hellfire diff? Is it completely compatable with a Twin? Such as bearings, drive cups, and the housing?
ThanX,
Krystopher
Old 11-16-2008, 08:33 AM   #6
Most 1/8th scale buggy diffs fit. Tower is a HPI dealer, Hot Boddies, and Ofna also work. I have some that work listed in the Mods Sticky. You could upgrade to 4 spider set up for more strength. Most of the buggy diffs are steel gears instead of pot metal like the Twin's. I don't have any complete diffs but I do have spiders, sides, and housings. I use the drives. If your interested let me no. PM
Old 08-08-2009, 10:58 PM   #7
I just installed a Ofna Hyper 7 diff and pinion in a MadForce axle
ou812 is offline   Reply With Quote
Old 08-29-2009, 05:01 AM   #8
I have a hyper 7 diff in my axle and it seams to slide from side to side
like the Hyper diff is to narrow ??
What is the width of the Kyosho and Hellfire diff at the outside of the bearing
SnoopMaxx is offline   Reply With Quote
Old 08-29-2009, 08:18 AM   #9
You'll need to shim it to keep the ring gear in proper contact with the pinion.
Old 08-29-2009, 03:30 PM   #10
I know that but it seems like 2.5-3mm ??
If I push it all the way over to one side the pinion don't have any contact with the ring gear
I think t
hat is too much
Old 08-29-2009, 03:46 PM   #11
Wow that isn't right. My diffs are 34.53mm to the outsides of the outer bearing races. That's fully assembled.
Old 08-29-2009, 03:50 PM   #12
Thanks Bart
I'll have to disassemble my axle to measure it
But just one more drive b4 I do
Old 08-29-2009, 03:54 PM   #13
you betcha
Old 08-30-2009, 04:39 PM   #14
15 Foot Jump with Hyper 7 VXL
Just a little taste
Old 09-04-2009, 02:53 AM   #15
The Hyper 7 diff is 33.3mm wide
Thats 1.2mm narrower
Old 09-04-2009, 01:30 PM   #16
Get a kyosho diff case. Most probably that will solve your problem.
MadForce is offline   Reply With Quote
Old 09-05-2009, 12:37 PM   #17
I might just get a complete savage flux diff
