Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: the new kyosho rock force.
Old 10-12-2007, 12:03 AM   #1
Default the new kyosho rock force.
kyosho is coming out with a new rock crawler called the rock force.. they have pics online from the 2007 tokyo hobby show..
jeff jenkins is offline   Reply With Quote
Old 10-12-2007, 12:16 AM   #2
Release your anger..
ThinkTank's Avatar
Link?
I checked and found nothing.
ThinkTank is offline   Reply With Quote
Old 10-12-2007, 12:32 AM   #3
all i saw was the pic that i posted .. and a buddy of mine is a sponsered racer from them and when we were at work he was talking to the kyosho team manager and he said they were coming out with a rock crawler..
http://www.pro-s-futaba.co.jp/hsphoto/prs-1.html
Old 10-12-2007, 04:46 AM   #4
EGRESSor is offline   Reply With Quote
Old 10-12-2007, 07:04 AM   #5
DAMN!!! thats one purty bulletproof crawler right there!
defenetly intrested in building a twin/force crawler
Its good to see that the big brands like kyoscho are jumping in the RCC scene
Like it
crawl rookie is offline   Reply With Quote
Old 10-12-2007, 01:05 PM   #6
That's disturbingly nice
Soya is offline   Reply With Quote
Old 10-12-2007, 01:35 PM   #7
Already being discussed here
new kyosho rock crawler
Rockpiledriver is offline   Reply With Quote
Old 10-12-2007, 09:32 PM   #8
Thumbs up
Hopefully this post will not turn into a steaming pile like the other one.
If the Rock Force does hit the U.S. market it will be some good times for the rc crawlers. I may even buy one. Or atlest get a set of axles to play with.
I want a set of those servo and a set of those link mounts!
_BEN_ is offline   Reply With Quote
Old 10-13-2007, 07:49 AM   #9
TEAM MODERATOR
Reflection's Avatar
I cleaned it up and deleted all the BS post
I'm VERY happy to see this rig. I want one....BAD!
I'd like to see it up close and see what it'll handle.
Reflection is offline   Reply With Quote
Old 10-13-2007, 10:51 AM   #10
sweet this is very exciting I hope all the big RC manufacturers start to notice rock crawling.
Blaze is offline   Reply With Quote
Old 10-13-2007, 11:32 AM   #11
i think its pretty cool. the only grip i see is that the shock ends are on ballstuds so than can pop off. needs more secure mount like a rod end.
looneybin is offline   Reply With Quote
Old 10-13-2007, 11:32 AM   #12
Yeah really!
I think that the lower links should have been mounted inside the chassis like this setup here.
New 2.2 Comp Tuber **Coming Soon** RCP Crawlers Prototype PICS
How much do you think it will cost to get a set of those servo mounts made?
Old 10-13-2007, 10:29 PM   #13
TEAM MODERATOR
Reflection's Avatar
Those are the same mounts the Mad and Twin Force use. I've run that style for years without a problem. Honestly,I've had many of the rod end style on the bottom of the shock wear out or break,the tops are still good.
My super is currently running CEN piggybacks but until these,I've always run the stock Twin shocks. Probably go back to them when I rebuild it this winter.
Old 10-14-2007, 06:24 PM   #14
Bart bender's Avatar
Three link front with servo in the chassis? There is a hawse fairlead in the rear, possibly a winch? Looks like there is a couple servos inboard too. One for the front winch? THose custom axles have built in skidplates too, nice touch. The lower links really do need to be inboard. Thats kinda the point of boat side chassis for clearance.
I second Raptorman on the ball studs. Never had a problem with that end of my shocks yet.
Bart bender is offline   Reply With Quote
Old 10-14-2007, 06:34 PM   #15
TEAM MODERATOR
Reflection's Avatar
There's a 2 speed tranny in there as well
Old 10-14-2007, 07:12 PM   #16
The steering servo looks a little under-sized.
Thorsteenster is offline   Reply With Quote
Old 10-14-2007, 10:54 PM   #17
TEAM MODERATOR
Reflection's Avatar
Looks like a 1:10 scale servo. I run 200 oz. 1:10 scale servo's(Airtronics 359's) on my Twin and they work nicely.
It's probably all the bulletproofness around the servo thats throwing your eye off
Old 10-15-2007, 06:43 PM   #18
Little better pic of the front. Sorry bout the size. You can see the details better. Geuss it isn't an inboard servo. Like the 3 link though. I see a hawse fairlead in there too
Old 10-17-2007, 03:42 PM   #19
The more I look at those servo mounts the more they look like some generic part. Like a hose clamp or something.
Is there anything that looks like those on the market...? :?
Found this:
http://www.myhelicopters.com/rc/Tail...t-TREX-450X-XL
http://www.trextuning.com/heliupservomounts.php
http://h1071671.hobbyshopnow.com/pro...od=MHETX4024SE
I doubt the tail boom is 1" in diameter though.
This one might work with some dermiling.
http://www3.towerhobbies.com/cgi-bin...?&I=LXNW31&P=7
Old 10-17-2007, 07:12 PM   #20
i have a question, why are the upper links in the rear not centered in the mount? is the pumpkin offset?
elbo is offline   Reply With Quote
