Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Pinion / spur options for the AX10 trans
Old 10-11-2011, 02:13 PM   #1
Default Pinion / spur options for the AX10 trans
To get higher gearing (for bashing), what options do we have for pinions an spurs with an AX10 trans? Are lower-tooth steel spurs available? What about 32P gears?
Mazlem is offline   Reply With Quote
Old 10-11-2011, 03:43 PM   #2
Nobody
Cordwood's Avatar
For durability and reliability, a great option is the supershafty top shaft.
Found HERE
Mix that with the 56 Tooth Robinson Racing steel 32p slipper spur, found HERE
Don't forget the rebuild kit with the springs, HERE
You can mix this with whatever 32P pinions you want. Pretty sweet setup, especially for a high power basher.
Cordwood is offline   Reply With Quote
Old 10-11-2011, 07:44 PM   #3
Hmm, spendy, but nice.
Old 10-27-2011, 08:46 PM   #4
Ok I've got the spur and slipper kit but I've only built one slipper clutch an that was 5yrs ago. Anybody got pics that show how to put all this stuff together?
