Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Supershafty BYB's - Setups and Show-Offs
Old 11-15-2011, 05:26 PM   #1
SuperShafty.com
Default Supershafty BYB's - Setups and Show-Offs
Hey guys,
I had a thought a little while ago that since at least 5 of us have these that we should give out setups. Lets start with a nice simple format so we can easily compare.
(((just copy and paste this)))
Chassis WB size: 12.5" or 14.5"
Wheelbase:
Wheels/Tires:
Axle Width:
Motor/Esc:
Tranny:
Gears (Pinion/Spur):
Batteries:
Servo:
Shocks (oil/springs/pistons):
PICS AND VIDS SHOULD BE UPDATED AS YOU UPDATE YOUR BYB
that should be about it for setups.
also show us pics if you can of what your BYB looks like. I will start it off
Wheelbase: 17"
Wheels/Tires: white HPI Blast narrowed to 1.25" and 40 Trenchers narrowed to 2.5"
Axle Width: 10.5" at the hubs
Motor/Esc: 55t integy with VXR Tekin on the way
Tranny: Axial SCX10 with HR Case, BWD motor plate, and steel gears, CDW steel outputs
Gears (Spur/Pinion): 87/14
Batteries: 3 cell 3300 Tunigy on the way
Servo: MKS HV300 500oz at 12v 430 at 8.4v
Shocks (oil/springs/pistons): Stock TF shocks springs and pistons, needs more work though
some pics.
mjderstine is offline   Reply With Quote
Old 11-16-2011, 11:15 AM   #2
Chassis: 12.5", 4 1/4" wide
Wheelbase: 14 9/16"
Wheels/Tires: HPI Super Mudders with narrowed foams on Maximizer 17mm 1/2" offset beadlocks
Axle width: Full-width axles
Motor/ESC: No motor/esc yet
Trans / gearing: Will have AX10 trans with 56T/18T gears to start
Batteries: 4S lipo batt
Servo: Hitec 7955 for steering
Shocks: Integy MSR11 shocks with 80wt in the RR and LF, 60wt in the LR and RF
Spool in the rear with dogbones
Open front diff with Ofna CVA's
Mazlem is offline   Reply With Quote
Old 11-17-2011, 01:31 PM   #3
SuperShafty.com
love the tires man. they looks awesome. should be great for bashing around!!!
Old 11-18-2011, 07:14 PM   #4
Bart bender's Avatar
I agree, that W/T combo looks nice
Bart bender is offline   Reply With Quote
Old 11-22-2011, 11:15 AM   #5
SuperShafty.com
com'on guys, i know at least two other guys have them. and maybe more. lets see them! even if it is a repost it would really help all of us who have them.
you too Rick. even though it is your baby we would love your expertise in the BYB!
Old 11-22-2011, 11:54 AM   #6
Nobody
Cordwood's Avatar
I was hoping to get mine at least as a roller before posting. I'm working on it...
Cordwood is offline   Reply With Quote
Old 11-22-2011, 12:24 PM   #7
SuperShafty.com
no worries there man. so are there only two runners out there now? Ricks and mine?
Old 11-22-2011, 12:47 PM   #8
Buggy had that aluminum-framed one going but last I read he needed a new motor for it, which was about a month ago.
Mine's still a ways off. I'm about ready to buy a brushless setup but there's still a few other things to do like figure out how to mount a 4S battery (maybe I should have gone with dual 2S' on the sides like a stock TwinForce!)
Old 11-22-2011, 02:46 PM   #9
Nobody
Cordwood's Avatar
I got side tracked with a couple other projects. I have everything I need, though. Should have a runner shortly.
Old 11-22-2011, 04:05 PM   #10
SuperShafty.com
why play with a basher when you have comp rigs to get ready right!
Old 11-26-2011, 02:31 PM   #11
Default V84x4's Basher
Sorry Guys........Been Busy
OK Here we go.........
My SuperShafty BYB
  • Chassis: "Snoop" BYB 12.5"
  • KYOSHO: Big Bore Shocks with "JeepinDoug's" Cups (The Shit)
  • Links & Skid: Hand Made 3/4" Delrin, SuperShafty Link mounts
  • Kyosho Axles: Stock Length with SuperShafty Spools & Helical gears
  • Power Plant: TEKIN T8 1950KV and TEKIN ESC
  • Battery's: 2 Thunder Power 2100mh 3S LiPo's in Series TO MAKE 6S
  • Trans: 8mm outputs, Topshaft conversion Robinson Racing 32P Steel Slipper 15T pinion, Hardened Aluminum gears
  • Tires: Cut-n-Shut trenchers
  • Wheels: Narrowed HPI Blast
  • DriveShafts: KYOSHO Upgraded Mad Force Using C Cups at the trans
  • Servo: HI-7980
  • BEC: Castle Creations
22 tooth pinion and 54Tooth Slipper was to much top end, so I lowered the
Pinion down to a 15 tooth and here's the video of it doing 38mph
KYOSHO MAD FORCE - YouTube
PM me with any questions
Best Regards Rick
v84x4 is offline   Reply With Quote
Old 11-27-2011, 06:58 PM   #12
SuperShafty.com
great pics, video, and setup man.
thanks for post this. i think its gonna help me make mine a go fast instead of a trail best!
