01-23-2012, 07:27 PM | #1 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Bobbed Deuce 2.2 with Kyosho Twin Force Axles
hey guys, some of you may have saw my tease about starting a new build. well here goes nothing. starting the slow build of a 2.2 scaler. planned setup will be... Gonna use that homemade Tube body i made and go for the Duece & 1/2 look, chopped to two axles of course. axles are gonna be some narrowed TF axles. probably around some wraith width. wheels are gonna be some custom jobbers so i can fit the 17mm hubs. still looking for this setup though. chassis makin a twin rail from scratch. just bent it up tonight. 1/2 steel. gonna start the hack saw and dremmel this week and should be split in a couple days. pretty much gonna be hackin and filin for a couple weeks while parts come in on the budget but excited to get this going. Last edited by mjderstine; 02-16-2012 at 10:40 PM. Reason: title change |
01-23-2012, 08:08 PM | #2 |
| Re: Military TF 2.2
been tweakin the chassis a lot. but what do you guys think so far, any glaring obvious things that dont look good?? heading for this look. Last edited by mjderstine; 01-23-2012 at 08:22 PM. |
01-23-2012, 08:13 PM | #3 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: Military TF 2.2
DUUUUUDE....... That's sick Is the Bed going to be a Covered wagon Style or just a Flat bed? This is going to be an Epic build for sure...........Subscribed Regards Rick |
01-23-2012, 08:29 PM | #4 |
| Re: Military TF 2.2
check above. i edited the post. gonna be a flat bed. i ahve the bed layed up too. might be a wooden bed, or a steelie one. still deciding. i have both built. the tube one has fold down sides too!! its gonna be a sweet truck when done by the end of the summer .... |
01-26-2012, 10:21 AM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Re: Military TF 2.2
A Bobbed Duece? This is SICK. Would be very cool if you could figure out some airbag suspension in the rear and leaf or coil in the front. Looks GREAT so far |
01-26-2012, 12:32 PM | #6 |
Thanks for the words bud. I have a couple updates and questions for you guys. But wont be posting them until tonight. Just got busy at work and am having laptop issues. Its probably gonna be a highly mossed bobbed duece with coil ove springs and a front panhard to start. But I van always add the other stuff later. anyway, glad the siye is back up too sent with my thumbs... |
01-26-2012, 04:06 PM | #7 |
| Re: Military TF 2.2
hey guys, got a little work done. got the chassis rails split. i used a basic dremel with the new EZ lock and 1.5" cutoff wheels. went through 4 of them, but it actually worked a lot better than i thought. and was def easier than a hack saw. also got the axle stubs from SuperShafty and got the axle mocked up. from hub to hub they are 240mm, a wraith is about 250mm. so i tihnk this might be good for now. do you guys think this is too wide?? or should i just go for it?? |
01-26-2012, 04:11 PM | #8 |
| Re: Military TF 2.2
I'd test fit some wheels and tires under that sweet body
01-26-2012, 04:21 PM | #9 |
| Re: Military TF 2.2
That EZ-Lock system is the bomb Judging by the looks of the bed i'd say they look wide enough but like Bart said "Mock it up" & lets see Regards Rick |
01-26-2012, 08:30 PM | #10 |
| Re: Military TF 2.2
working on the mock up, got the skid plate figured out now. at least a tester for the time being. hmmm. rick, any ideas how to mount leafs to a TF axle? |
01-26-2012, 09:59 PM | #11 | |
| Re: Military TF 2.2 Quote:
Hmmmmm........... Off the top of my head How about a small piece of angel aluminum coming off the top hole of lower link mount and aim it back towards the axle Or a piece of 1/4 delrin in the shape of an "L" but turn it side ways so that the "L" is laying across the top of the axle and the other part of the "L" bolts to the lower link Oh Wait !!!!! Your not using Lower Link mounts.....Duhhhh OK......just use a small piece of delrin and curve it out to match the curve of the axle Then bolt it to the axle and attach your leaf spring to the flat part of the delrin I can draw you something up if I'm not explaining my self..... Regards Rick Last edited by v84x4; 01-26-2012 at 10:03 PM. | |
01-26-2012, 10:29 PM | #12 |
| Re: Military TF 2.2
yeeah, guess i will have to use the ones in the mail to supplant other builds. i tihnk i get it. i think it would be like having something like your servo mounts but only 1/2" long. i might be able to get something like that going tomorrow. at least i can start making some beta versions out of some cutting board. guess who bought a nice 15/16" forsner bit the other day just for this type of scenario. i can have this part mocked up very soon now!! then its making some shackles. you explained yourself very well. not sure why i didnt think of it since i bought the tools to make something like that already. next will be getting some leafs that i think are tough enough, anyone have experience with that type of scale building.? oh speng most of tonight lining things up for wheelbase, and just staring at this thing thinking about either a transfer case, front mounted tranny, long long driveshafts then getting the servo mount done. all sorts of fun. WB is right at 13" so might stick with something like that, but its probably gonna be different than that. oh and kinda like this really simple look! Last edited by mjderstine; 01-26-2012 at 10:38 PM. |
01-27-2012, 05:41 AM | #13 |
| Re: Military TF 2.2
As it sits on the table there, I'd say your axles are still gonna be too wide. Unless you want the tires sticking out some. Hmm, you sitting at 10 1/2-11" axles. They could go narrower but that'll take some custom shafts.
01-27-2012, 09:54 AM | #14 |
| Re: Military TF 2.2
that are actually 9.25 from mounting hub to mounting hub. but yeah might be a tiny bit wide. but i am not gonna cut them down til i get some wheels and tires in stock. so next big purchase is gonna be for some custom wheels... anyone making some? |
01-27-2012, 10:09 AM | #15 |
| Re: Military TF 2.2
2.2 17mm hex? Custom is the only way I no of. Unless there is something in the works with the big man.
01-27-2012, 11:06 AM | #16 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| Re: Military TF 2.2
hey here is some of the things i turned down on the lathe. I still need to cut the barrels apart but I think they look cool. Im going mess around with some more stuff any ideas? |
01-27-2012, 11:09 AM | #17 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: Military TF 2.2
Loving that body MJ. I, too, would vote to narrow the axles, but waiting for wheels first makes sense. Didnt Rick just make some 12mm hexes for TF axles? |
01-27-2012, 11:48 AM | #18 |
| Re: Military TF 2.2
Well, Buggynut is offering to make you some wheels |
01-27-2012, 12:18 PM | #19 |
| Re: Military TF 2.2
yeah, looks like he could make me some cool ones out of wood for me!! yeah, which vendors on here would be willing to do that for me. i'd even go for some delrin ones like the ezlock ones from rpp CAC EZ-Loc 2.2 Beadlock wheels (4) those barrels looks sweet man nice job there! well got some prototype axle leaf mounts done today. gonna start workin on the shackle mounts too. |
01-27-2012, 12:34 PM | #20 |
Gold Star Baby! Join Date: Jul 2011 Location: Warren, MI
| Re: Military TF 2.2
It would be sweet to use mad force axle and make a top loader axle like the Rockwell for a more scale look.
Bobbed Deuce 2.2 with Kyosho Twin Force Axles - Similar Threads | ||||
thank your military | freakofnature | Chit Chat | 7 | 02-18-2011 03:47 PM |
Military | country_crawler | Chit Chat | 22 | 10-05-2010 05:11 PM |
anyone know there military jeeps? | STANG KILLA SS | Chit Chat | 27 | 08-31-2010 10:17 PM |
Military | John Deere | Chit Chat | 21 | 02-24-2010 08:25 PM |
Our Military | Rockkid | Chit Chat | 63 | 02-15-2008 02:57 AM |
