07-28-2006, 09:55 AM | #1 |
Newbie Join Date: Jul 2006 Location: Laredo
| Mad Force / Twin Force, same axles/gearing?
My LHS has a madforce for sale for $250, and since I haven't been able to find a single twinforce for sale at any of the hobbyshop's I look online for, I'm not sure what to do. Does the MadForce and Twinforce have the same axle assemblies, or is one weaker than the other, etc..? I figure I can part out the radio system and motor for at least 150. Let me know what you guys think I could do, or show me where I can get a TwinForce from :/ Thanks, JohnR |
07-28-2006, 10:27 AM | #2 |
RCC Addict Join Date: May 2006 Location: USA
i would take a look at the box. im pretty sure they are the same.
07-28-2006, 11:15 AM | #3 |
RCC Addict Join Date: Jan 2005 Location: Germany north
i have a set of new TF axles , lmk if interested ;) the rest of the Twin/Mad Force is useless |
07-28-2006, 11:44 AM | #4 |
there are a few differences, but the parts are all interchangeable. Unless you hold both types of axles in your hand, you would never know it. I think the mad force comes with a hardened rear pinion and ring, aluminum front. The twin force comes with both steel pinion / ringsets i think. At any rate you will want to shim the diffs properly. The diffs / knuckes/ outputs are 1/8th buggy as well, so you can find replacement parts everywhere. On my mad force axles I swapped the outer stubs and knuckles with Savage ones. Now maxx rims bolt up. Otherwise you gotta deal with the hugo stub. |
07-28-2006, 12:17 PM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Twin Force has aluminum ring and pinions and the Mad Force has the steel.
07-28-2006, 12:58 PM | #6 | ||
As for the Mad tranny,I've never seen one in person. I'd like to just to see if theres any possabilities. I believe it might be a decent unit. Quote:
Nope,the Mad front is a steel helical cut gear and the rear is aluminum. The Twin is aluminum front and rear | ||
07-28-2006, 02:12 PM | #7 |
Sorry I thought the rear was steel too. My Bad.
09-30-2006, 02:50 PM | #8 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
x-factor and twin force axle housings are they interchangable? I reaworked my friends x-factor and except for the nasty square housing the truck turned out great....
09-30-2006, 08:21 PM | #9 |
The mad force rcx edition has hardened steel gears front and rear, along w/ beefier spider gears. Lmk if u need anything.... |
09-30-2006, 08:24 PM | #10 | |
I guess that IM asking is if the axle cases are in interchangable between the x factor and the madd/twin force........ | |
09-30-2006, 08:27 PM | #11 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
09-30-2006, 08:29 PM | #12 | |
10-02-2006, 12:34 AM | #13 | |
