01-28-2013, 04:13 PM | #1 |
Pebble Pounder Join Date: Oct 2012 Location: Harleysville
| My Mad Force
She's not a crawler but wanted to send a couple pics out. It is still far from geing done but its my baby, had her since she first came out. She keeps my fleet of Losi LSTs company. She hasn't been out in years, tires off and all packed into a rubbermaid for about 5 years+. I felt guilty and decided to get a new frame and rebuild, unfortunatelly no frames are available so decided to make one and decided to lower the motor. Let me know your thoughts. Specs below: -Mad Force, 1st generation -Mach .26 with Losi HT pipe -a mix of stock bearing and ceremic bearing (slowly upgrading) -Homemade frame -Homemade 4 links with 4 link mounts -Homemade steering links -Homemade steering servo (behind the axle) -Ofna monster pirate wheels, 17 mm -Proline dual rate shocks. -Imex Baja Claws -Has the 4 gear mod in the diffs |
01-28-2013, 08:02 PM | #2 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: My Mad Force
look angry. i like it
01-29-2013, 05:43 AM | #3 |
Pebble Pounder Join Date: Jul 2009 Location: Suomi Finland PERKELE !
| Re: My Mad Force
Niiice ! is that the 10'th scale or 8'th scale body ? do You remember what oil weight You use in diffs ?
01-29-2013, 07:13 AM | #4 |
| Re: My Mad Force |
01-29-2013, 07:18 AM | #5 | |
| Re: My Mad Force Quote:
If memory serves me correctly, I'm running 50k in the diffs. | |
01-31-2013, 04:15 PM | #6 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Re: My Mad Force
I do miss my go fast TF for sure. I do no that when you run a 4 link you will need to put in beefier hiem joints than Jato/Revo though. I found some huge ones (not available anymore) and ran 3/8" al rod for lower links.
02-11-2013, 08:13 PM | #7 | |
Haven't had much time to work on it since I've been quite busy. lookAnyway painted the bottom portion of the frame and the upper 4 link mounts. Also, made the rear sway bar. Alot more work to do. Some pics of the sway bar and steering servo mount. If you look closely, you can see the steering servo mount. Last edited by Stonewall; 02-11-2013 at 08:20 PM. | |
02-14-2013, 11:37 AM | #8 |
| Re: My Mad Force
Would the Losi ends be these ? I just got mine from Amainhobbies after two weeks of intense waiting |
02-14-2013, 05:57 PM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
| Re: My Mad Force
Looks very cool!
02-14-2013, 07:58 PM | #11 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| Re: My Mad Force
I like the traxxas jato rod ends. I like the amount of thread bite you can get. I can get a pic if you need one tomorrow. |
02-15-2013, 02:55 PM | #12 |
| Re: My Mad Force
I have broke far more Jato ends than Revo ends. (L to R)Traxxas, Revo, Kyosho, Jato, Ofna front camber link, Ofna rear camber link, can't remember but that is the one you can't get anymore Last edited by Bart bender; 02-15-2013 at 03:13 PM. |
08-16-2013, 08:28 PM | #13 |
| Re: My Mad Force
Made some headway. Still have quite a bit to do but is coming along slowly, reeeaaal slowly. Onto pics. The lights do work. Need to install the rear sway bar and install the plexi side shield. ...and topless..... |
My Mad Force - Similar Threads | ||||
Can somebody please identify these axles as rock force or mad force? | 97sfeclipse | Kyosho Crawlers | 2 | 03-27-2010 04:59 PM |
Difference between X-factor, Twin Force and Mad Force axles | Flatty | XTM Crawler | 1 | 09-11-2008 05:48 PM |
Mad Force / Twin Force, same axles/gearing? | JohnR | Kyosho Crawlers | 12 | 10-02-2006 12:34 AM |
