05-31-2007, 01:24 PM | #1 |
Quarry Creeper Join Date: Jan 2005
| Caster
When building Twin Force crawler axles, do we want to build in a small amount of caster, or do we really need any at all?
05-31-2007, 02:11 PM | #2 |
I joined the Band! Join Date: Sep 2006 Location: ...
what is caster?
05-31-2007, 03:57 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
castor is the difference between 0 and 0 looking at the SIDE of the axle camber is the difference between /--o--\ when looking at the FRONT of the axle toe is the difference between \--v--/ when looking at the TOP of the axle The wheely king axles have about 15-20* of castor on their axles. If you stand the axle C's upright to remove the castor, you have now "clocked" the axle. |
05-31-2007, 08:50 PM | #4 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
I am running a bunch on mine. Does it help? Heck, I dunno. It works good for bashing, so why not? Plus it allows me to easily run BTA steering ;)
06-07-2007, 12:28 PM | #5 |
| Caster
When scratch building/assembling TF axles for a super class crawler, would you set them up with, or without caster? (If not using BTA steering).
06-07-2007, 08:00 PM | #6 | |
It's your choice really. It's not needed and like anything else,theres pro's and cons to it. What I'm gonna try when I rebuild my super class Twin this fall is camber. I think I can gain a little with different camber settings. Not possitive but I'd like to try it anyway. | |
06-10-2007, 04:00 PM | #7 |
| Caster
Thanks Raptor, Please let me know...what would you say are some of the pro's, and what are some of the cons? |
