09-09-2008, 07:05 PM | #121 |
Quarry Creeper Join Date: Oct 2004 Location: illinois
Junk?
10-11-2008, 08:22 PM | #122 | ||||||
| Yeaup! Don't be so pruney man. It was more of a common phrase than anything......This thread is about my junk. Gotta work on my junk this weekend. Ya follow me? The Maxx trannies are pretty stout and reliable trannies. They have allot of slack in them and they place the motors up high,which are two BIG downfalls in a comp crawler. I know they can work well in certain rigs and you seem to be happy with yours. They aren't the best when your trying to build a small,compact and yet very strong set up in a comp crawler. Quote:
Running an RX pack was a real common thing before the Castle BEC came out. High voltage packs cut your BEC in the ESC down a good deal. The only way to get the servo's good power again was either a funky wiring harness or an RX pack. Running a Castle BEC is ALLOT better because it's easy to mount,fully adjustable via the Castle link and you decide how much power your servo's get. They are also,in some cases cheaper than an RX pack and you have one less battery to charge up in order to run. Running an RX pack can work good,I've run them in the past with great results. Quote:
Anthony does have some really slick ideas and quality parts. :whittylittlevoice: I know. :wittylittlevoice: Last edited by Reflection; 10-11-2008 at 08:29 PM. | ||||||
10-12-2008, 03:13 PM | #123 |
Here's the pictures of the "shelf" I use for my Mamba Max ESC,Castle BEC and the Spektrum RX. I wanted to fit everything but the servo's and battery in the belly of the Hustler. It was a tight squeeze,but I got it all in there. It's just a piece of 1/4" delrin. You can see in the 2nd picture where I trimmed out a section to clear the motor. I figured where the motor would sit. I used a 1 1/4" end mill at work and just made one swipe .125 deep. There's plenty of clearance for the motor now,even my big outrunner. If I remember right,the puller would fit without cutting that section out. I wanted the option to run a bigger motor plus have some adjustably. There's just 2 countersunk 3mm bolts holding it to the chassis,you can see them in the 2nd picture as well. I'd have to take the rig apart,but I can get more pictures if you like. Last edited by Reflection; 10-12-2008 at 03:17 PM. |
10-19-2008, 10:17 PM | #124 | ||
The outrunner I ran in this for a while was a Hyperion 3025-8. I was told that if my cells could deliver,it'd push right at 2 horsepower. The pullers are stout little motors,but not that stout. They've got pleanty of low end grunt,you won't be disapointed. I couldn't tell you the exact difference in power since I don't have anything to really test that myself. I personally like the 10t pullers better. They'll stay a little cooler under high voltage and in heavier rigs. A 10t is slower than a 7t,but they've got pleanty of speed for a crawler. The slow speed control these pullers provide is SICK! Quote:
Do you have metric drills? If so,use a 6mm and drill the flats out of all the yokes. Then,the yokes that will go on the pinion of the axle,use the 8mm and open them up. Anthony's 6mm outputs are already drilled for the Traxxas pins that come with the Revo's. You'll have to drill the pinions on the axles for the pin though. They are case hardened,but they'll drill like butter if you sand the case hardening off only where the hole will be. There's really no need in doing the 2 female shaft deal with Revo's. You can if you want to though. You'll be hard pressed to twist them. I have twisted a Revo before,but it was an old shaft and I was really pushing my truck that day testing a few things out. Last edited by Reflection; 10-19-2008 at 10:28 PM. | ||
