03-09-2010, 04:31 AM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: Bucktown
| Project Vitamin "G"
yep i said "G" (Gas+oil=2cyc) Crawler, maybe basher you know it. here we go 23cc gasser 2speed tranny, revo reverse maxx hybrid axles Nylint 1/6 jeep body ? ? ? Pics soon to come http://i695.photobucket.com/albums/v...524102305b.jpg BIGGER IS BETTER Last edited by 12voltfun; 12-22-2010 at 03:59 PM. |
03-09-2010, 10:08 AM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: Augusta
Very interesting. I'm looking forward to it. 8-) |
03-10-2010, 12:58 AM | #3 |
Rock Stacker Join Date: Oct 2009 Location: Brillion
| gas crawler |
03-10-2010, 01:50 AM | #4 |
Pebble Pounder Join Date: Aug 2009 Location: Glenwood Springs
ohhh.. I cant wait to see this one either!
03-13-2010, 09:26 PM | #5 |
got some pics and more ideas I would like to mount the tranny close like that but it will make it spin the wrong way.(dam one way barrings) so it will probable mount in front like this any one have any ideas BIGGER IS BETTER |
03-13-2010, 11:43 PM | #6 |
Newbie Join Date: Apr 2008 Location: BRITISH COLUMBIA
wow, i am really looking forward to seeing this!
03-14-2010, 02:48 PM | #7 |
same issue I had with my gasser. Check my build thread and it may give you a few ideas on mounting stuff
03-14-2010, 08:33 PM | #8 |
Well I think I got the lay out figured out, for the engine and tranny at least what you think? fixed the spur gear hiding the front output shaft thing, useing #25 chain and sprokets as a jack shaft BIGGER IS BETTER |
03-15-2010, 04:13 AM | #9 |
Well after sleeping on it I think im going to make the frame a twin plate style out of aluminim plate should be good and ridged BIGGER IS BETTER |
03-15-2010, 07:30 AM | #10 |
Pebble Pounder Join Date: Jul 2009 Location: Calgary, Ab
2 strokes will generally run backwards pretty well. If it's got a reed intake, it'll probably run exactly the same in either direction. Just a thought... You'll need to re-do the starter scheme at least. |
03-16-2010, 09:53 PM | #11 |
working on frame mock up BIGGER IS BETTER |
03-18-2010, 04:15 AM | #12 |
still looking for a piece of 1/4" aluminum plate for the frame rails BIGGER IS BETTER |
03-20-2010, 07:58 PM | #13 |
Still trying to get the frame setup nailed down whatcha think? BIGGER IS BETTER |
03-23-2010, 05:34 PM | #14 |
Newbie Join Date: Apr 2009 Location: Los Angeles
Sorry I have absolutely no experience with gas/nitro rc. How will this drive once done? Would it be geared for crawling speed or is it a matter of feathering the throttle?
03-26-2010, 06:52 PM | #15 |
05-03-2010, 07:32 PM | #16 |
well its been awhile but I have made some progress. Got the rear axle built and mounted , tranny is in, and i cuoldint help my self , so i started it and ran it (with the rear on only) its not that fast in first but lotts of power. Im going to need more brakes to handel this thing bigger is better |
05-04-2010, 10:37 AM | #17 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
Awesome update!!! Cool chasis design! One of these days I'll be brave enough to try something like this! |
05-05-2010, 07:53 PM | #18 |
Pebble Pounder Join Date: Dec 2009 Location: salina,ks
great build you should make a vid of it running
05-08-2010, 10:24 PM | #19 |
Quarry Creeper Join Date: Sep 2009 Location: redding ca
nice build think a gas crawler idea would be sweet |
05-09-2010, 09:26 PM | #20 |
well not to much new but the front housing, still need mounts (links shocks trackbar) Its a tight fit BIGGER IS BETTER |
