07-07-2010, 08:11 PM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Wheels for a Willy's Jeep?
Anyone know of a producer or vendor who sells an appropriate 2.2 wheel for a Willy's Jeep conversion? I want alloy wheels, but as long as they look era-correct and hold up well, I guess it doesn't matter what they are made of. Thanks! Jason |
07-07-2010, 08:30 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
I've seen a few of these builds with Alum Landies from RC4WD. Is this what you were looking for? http://www.rc4wdshop.com/go/product_...roducts_id=523 |
07-07-2010, 08:56 PM | #3 |
Thanks! They are probably as close as I will find to the original wheels, so unless someone else knows of some exact copies of the Jeep wheel, I'll get those. I appreciate your help! Jason |
07-07-2010, 09:19 PM | #4 |
I also saw these Humvee wheels: http://www.rc4wdshop.com/go/product_...roducts_id=720 Maybe if I install the bolts inward so that only the heads show and add some center caps over the lock nut, they would more closely resemble the original. http://i601.photobucket.com/albums/t...sJeepWheel.jpg |
07-07-2010, 09:44 PM | #5 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
07-07-2010, 10:20 PM | #6 | |
| Quote: Just curious, did Bartos charge the usual amount for the wheels or is there any sur-charges involved? I just narrowed some plastic Imex wheels and I narrowed some Flat Irons for my Willys, and I'm not happy with the results of either one. Just for giggles, I mounted up some Chisels on RC4WD comp wheels, they fill the wheel wells nicely and scale out to about a 33" tall tire, I just have NO turning radius with them. | |
07-07-2010, 10:43 PM | #7 | |
I remember reading on another build that the guy had to move the front axle out a little because he had a hard time getting the steering he wanted.... | |
07-08-2010, 02:35 PM | #8 | |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
07-24-2010, 09:47 PM | #9 |
Quarry Creeper Join Date: Oct 2008 Location: Oakley
If your still looking for wheels, send me a photo of what your looking for and I can quote you a one off set. Regards, Chuck |
07-25-2010, 03:19 AM | #10 |
RCC Addict Join Date: Apr 2008 Location: Singapore
07-25-2010, 07:59 PM | #11 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
I just thought I'd throw a random thought in here, because it's been bugging me since I received my 1/6th Jeep. I know everyone uses 2.2"s, and there are some great looking Jeeps on here and elsewhere, but in 1/6th, 2.2"s are just a touch over 13" scaled up. I've been trying to find tall rubber for 2.8"s, but no luck.... That's all. I'll suck it up and use 2.2"s like everyone else but I just had to put it out there |
07-29-2010, 01:27 PM | #12 | |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
I just changed my tires to 2.2 rock crushers, I have lost a lot of crawling ability.... but with the weight of these jeeps and scale goodies, the soft tires, colapse under it's own weight and creates no ground clearence under the diff. now I have ground clearence and a stiff sidewall ....really helps with the steering. no more push I have run... flat irons, panthers, chisels and hammers all of them tend to "roll under" when turning and side hilling. you can stuff them (which i did) it helps on the "roll under" but you lose a lot of the tire's ability. the best tire, out of our group of willys, is the 2.2 rok lox.... stuffed. They still tend to "roll under" a little, but they hook up great and give you the diff clearence needed. narrow and tall.....seems to scale best. my videos show all the different tires I've tried. you can see for yourself and make the choice thats right for you. | |
