02-02-2012, 04:15 PM | #1 |
Newbie Join Date: Feb 2011 Location: garden grove
| where to start
i have a 1/6 truck i want to make a hobby quilty 4x4 without breaking the bank but im not sure what to start with. is 1/10 strong enought(lowrider navigator is kinda heavy-for now anyway) or is 1/8 the only way to go and what kit or axels, motor/esc, spring/links should i get. im thinking the maxstone8 or mad toqure8 from exceed. any help would b awsome.
02-04-2012, 05:13 PM | #2 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
| Re: where to start
you should post up a picture of the body so people can suggest what axles to use ,i would stick with axial wraith or wheelieking axles and you will probably need to make your own chassis.
02-04-2012, 07:24 PM | #3 |
| Re: where to start |
02-04-2012, 07:31 PM | #4 |
| Re: where to start
here are some pics so u can see what im working on. i figured i would make a chassis but just dont know what scale or what parts will handle the stress. 16''wb about 10'' wide and on the heavy side
02-04-2012, 10:04 PM | #5 |
| Re: where to start
The best way to start is to get some graft paper and draw out a full size "blue print" of sorts so you can get a feel for how everything might fit together, it will save a LOT of headaches down the road.
02-08-2012, 12:37 PM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Re: where to start
With 10" body width, are you wanting to keep the tires/wheels tucked in or wider track with them hanging out? Maxstones with 2.2s on them are 14+" wide. Are they all MOA? Not many guys build MOA scalers. A good set of Axials with the right hardware will hold up just fine. |
02-08-2012, 07:52 PM | #7 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| Re: where to start
Go talk to rick at supershafty.com he is great at coming up with ideas and can probly make your axles to fit what you want. I would say also check out the build in the twin/mad force area. JMO Also think about what you want, as in 4link,leafsprings and full frame or tube frame, scaler or crawler. IMO I would go with a full lenght frame made out of 1/2 square tubing. I would thow some tires next to it and see what size you might want to use. Just some ideas |
04-20-2012, 06:54 PM | #8 |
| Re: where to start
the build has started. I just finished the four link but need to mount the rear springs(may switch to droop set up) check out the build thread on westcoastrccrawler.com (large scale). you wont belive what is going to power this monster(hint)
where to start - Similar Threads | ||||
where to start | 001jeepcrawlin | Axial XR10 | 2 | 12-08-2010 10:02 PM |
Where to start?? | AK-Maxx | Axial AX-10 Scorpion | 8 | 10-29-2009 09:08 AM |
where should i start? | Semi Pro | Axial AX-10 Scorpion | 8 | 10-27-2009 07:14 AM |
where should i start | srx | Newbie General | 10 | 04-01-2008 04:38 PM |
Its a start | justadork | Tamiya Txt-1 and Juggernaut | 1 | 09-18-2006 12:39 PM |
