Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: 1/4 or 5th scale scale rock crawler?
Old 01-20-2013, 03:47 PM   #1
Default 1/4 or 5th scale scale rock crawler?
oki have been thinking about a 1/4 scale or 5th scale rock crawler. now im talking about a rock crawler about the size of the hpi baja or losi 5ive trucks. a crawler that used the shocks from either of these alond with the bodies. it would be massive and its a dreami have been kicking around for some time. i figure the losior hpibead lock wheels would work great. but where my dream runs into a snag is the axles and drive train.i think that the hpi baja tranny could be used with a modded motor plate fixed to it with it in the center of the truck? or i figure if its a ladder frame designe to keep the scale experience the the motor would be up front witha gearbox in the middle. i figure an rc4wd gear box would handle it but im still missing the tranny??
so what do people think ideas? maybe i could start amassing parts to try to do this ?? but it would be awesome. then the electronics are an issue. i figure a possible candident for motor would be a drill motor?
i need ideas and possible tips or links to products.
now the reason i pick the losiand hpiis because i have both of these large scale trucks along with a couple crawlers.
bob
dybbob is offline   Reply With Quote
Old 01-20-2013, 04:04 PM   #2
Default Re: 1/4 or 5th scale scale rock crawler?
im thinking maybe a disruptor style set-up.
Disruptor Ultra Compact Planetary Transmission (Limited Edition Red)
i think a setup like this would be perfect for a GIANT 1/4 scalethe size of the hpibaja or losi 5ive.
note: this is a pic i found on rc4wd it is for the disruptor transfer case i am only using it for reference. this is not my pic!
Old 01-20-2013, 04:08 PM   #3
the price makes me cringe. but it would work
The Ultimate Scale Yota 1/5 Axle Front
theloudone is offline   Reply With Quote
Old 01-20-2013, 04:16 PM   #4
ok here is a thought why couldnt the hpi tranny gears be used to make a transfer case>
note: not my pic found it on google
Old 01-20-2013, 04:20 PM   #5
THATS! what im talking about. but OUCH! your correct loudone the price is outrageous. but for something that big made of aluminum with those scale looks i understand the price.
sad thing is im like hummmm?? what could i seelto afford a set of these hahahaha.
no rely im thinking.
Old 01-20-2013, 05:00 PM   #6
If you thought 10th scale custom buids were expensive you have no Idea what your in for with large scale and add on the engineering challenges to boot, if you just want to throw a large rig together you can get away with alot less but to perfect a custom one off build plan on manufacturing a great deal of the parts yourself.
I'm in 1500 so far and only half way done
Diesel-tech is offline   Reply With Quote
Old 01-21-2013, 01:20 AM   #7
thats what i figured deisel-tech. until i saw those rc4wd axlesbut your correct i would have to find someone willing to machine alot of the parts although i do know several people that could handle the job but the money scares me alot.
but im just shooting ideas and seeing if onyone has tried it or done it and if so i would like to see how they did it.
Old 01-21-2013, 04:09 PM   #8
Here ya go man, RC4WD $999.99
  • CNC machined Killer chassis
  • CNC machined Killer axle
  • Billet Demolisher monster size wheels
  • Demolisher monster truck tires
  • Heat treated stainless steel spool gear
  • Max volume adjustable piggy back shocks
  • Killer angled suspension arms
  • Front and rear billet bumper
  • Full metal steering kit
  • Full ball bearings
  • Articulate 90 degrees
  • Gear ratio: 30:1
  • Length: 780mm/30 inch, Width: 545mm/21.45inch, Height: 250mm/9.84inch, Axle ground clearance: 80mm/3.14inch, Middle ground clearance: 160mm/6.3inch
  • Wheel base: 22.4" (570mm) wheels on-center
  • Weight: 9kg/20lbs
You can get one RTR With Dual Brushless for $1299.00 Regular $1699.00
TJ Steve is offline   Reply With Quote
Old 01-21-2013, 05:00 PM   #9
darn if only is was a shafty ... i'd buy one then play with it once rob a couple parts from it and then put it on the shelf with all the other donor rigs....
Old 01-22-2013, 10:47 AM   #10
Ditto
simon170 is offline   Reply With Quote
Old 01-27-2013, 04:38 PM   #11
he is my 1/6 gas crawler
12voltfun is offline   Reply With Quote
Old 02-01-2013, 09:44 PM   #12
I can't say I've ever seen a gas crawler. What gear ratio will it have?
SnarkyMcSnarkson is offline   Reply With Quote
Old 02-06-2013, 08:28 PM   #13
You have a build thread on that gas crawler? Would love to know more...
Sent from my HTC6435LVW using Tapatalk 2
TnMan is offline   Reply With Quote
1/4 or 5th scale scale rock crawler? - Similar Threads
1/8 scale rock crawler jeffmalone Newbie General 4 01-23-2012 09:19 PM
crawler store savage 5th scale conversion drkuhar General Crawlers 2 10-05-2011 09:40 PM
Who says 1/5 scale cant fly? San diego county fair 2011-rc show- 5th scale long jumps The Cow Non Crawler RC's 2 06-24-2011 07:20 PM
