11-05-2012, 09:37 AM | #1 |
Rock Crawler Join Date: Feb 2012 Location: Wisconsin
| What shocks to use ?
I'm working on a 1/6 Willy's Jeep and was wondering what shocks to use on it. It will be configured as a regular ol rock crawler. Using Wheelie King axles. I want to mount the upper portion of the shocks on the inside skirt of the wheel wells. Any suggestions for mounting locations within the wheel well are welcome... Thanks! |
11-05-2012, 11:29 AM | #2 | |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
| Re: What shocks to use ? Quote:
11-05-2012, 01:49 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Stock SCX10 units on my Willys, they work surprisingly well. And there's a crap-load of different spring weights available to fine-tune things...
11-05-2012, 03:31 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: Home
I use the rc4wd dual spring 110mm blue shocks. They are a good length but they stick a little bit, if there was no stick they'd be perfect in my opinion.
11-12-2012, 07:53 PM | #5 |
Newbie Join Date: Jan 2009 Location: Whitehall
I too have found that the SCX10 daul rates are good on large scale. I started off with a set of them on Big Blue, and I am now using them on the rear of The SS. I intend to use them on the front of the 2002 avalanche. You can get stiffer or lighter springs too. They are a great budget build schock.
11-14-2012, 03:39 PM | #6 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
i got kyosho velvets with mini t springs and jeepin doug c cups... not sure if theyll be stiff enought but i guess ill find out...
12-04-2012, 10:16 PM | #7 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
I run g transition 1/8 scale shocks in droop on my Willy's with wraith axles and about 8 ounces in each tire and they work awesome. I run them upside down too to keep them from weeping :( but overall they work really well. My rig is also 14.5 lbs
