Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: GI Wraith Jeep
Old 10-05-2014, 04:39 PM   #1
Talking GI Wraith Jeep
So JUST bought this. The price was RIGHT, came with a hacked FlySky3, 2 2200 3S Lipos.
Speed Passion Sensored 17.5 Brushless ESC, complete lighting system, and winch.
First impression is he did a good Job fabricating. I needs MUCH longer shocks, as the stock Wraith shocks can't handle the weight or length.
It's got 2 axial transmissions, so I need to swap out to a transfer case. Also plan on making a rear bumper/slider.
Also want different tires, but would like to know what works, looks best on these.
Anyway, enjoy.
BuddhaTat2 is offline   Reply With Quote
Old 10-05-2014, 07:27 PM   #2
Default Re: GI Wraith Jeep
Some pictures I took. See how wraith skid was attached, and the second trans. The motor shifted and the spur gear isn't aligned now. But that mean I get to take it apart. Have to almost take the front end out to get to the 4 motor hexs. Gonna switch out the polished trans upfront, and order a transfer case from rc4wd.
Old 10-05-2014, 07:46 PM   #3
Looks like a good purchase, and not a bad job getting that second trans in there as a transfer case, didn't have to cut the floor boards. Could have cleaned up the cuts better, but still looks better than the way I hacked mine up.
Mike Flea is offline   Reply With Quote
Old 10-05-2014, 08:13 PM   #4
I plan on doing some body work with styrene, and actually painting the entire thing HAZE GREY! As a 8 year Navy Vet, this will be the Shore Patrol Jeep. Was also thinking about rear steering. Without me doing an obviously quick search, does it help?
Old 10-05-2014, 08:45 PM   #5
I think rear steer is a personal choice, I don't know personally because I have never run a rear steer vehicle. I too, need to start adding some styrene, mainly for the trans hump. I've been through all the jeep build threads here, and I don't remember seeing rear steer on a Jeep, so yours would be unique. Some of the 6x6's and larger buggies have it.
Old 05-12-2016, 04:08 PM   #6
Hey is there any more pictures and info about this build
Cause I'm starting a 1/6th scale Jeep Mutt build
It's in the Large scale section
And wanted you input on your suspension setup
kgb424 is offline   Reply With Quote
GI Wraith Jeep - Similar Threads
Is that a Jeep??? And A Wraith??? SmokeScx10 Videos! 0 09-16-2013 08:52 PM
wraith jeep body Superboy Axial Wraith 7 06-12-2012 07:37 PM
Wraith Jeep Body Blondie Paint and Body 13 01-15-2012 09:44 AM
