Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: styrene willys build
Old 10-11-2014, 10:06 AM   #1
Default styrene willys build
Wasnt getting much of a response from people in the scx thread so I thought I would post it up here and see if you guys are more interested. I have a 1:1 cj3a that I have been building and wheeling for a while, but am now up in college and had to leave the old girl behind. I picked up one of the scx10 deadbolts and decided to build my own body for it, cause the Hasbros are gettin pretty rediculous on EBAY. Even though I have never worked with styrene before.
On to the Pictures.
[IMG] photo front_zpsa28a617d.png[/IMG]
I started off drawing this up to get an idea what I was after, sort of a rock bouncer mixed with a crawler buggy.
Sketch up then let me do a print out of all the pieces and exactly how they would need to be cut and bent.
[IMG] photo IMG_0392_zps6d3364da.jpg[/IMG]
After a few days of messing with the tubes and gettin frustrated with the styrene tube, I decided to move on to something a bit easier, and luckily the old flatty's have pretty flat pannels. I forgot to take pictures for the first day so It will just start where I started taking pictures.
Here it is side by side to the deabolt body, pretty close in dimensions.
I then got bored one night and instead of following my original plan I decided to just finish out the back half of the body.
Heres a picture of my 1:1 for a little reference. It is on custom width 44's and 35 km2's. I built the axles and pretty much everything on it in my driveway. I love the low center of gravity trend that has been going on for a little while and decided to follow that, it is on less then stock springs, and only sits about 2 inches taller then a bone stock willys. While still having plenty of travel for the Rubicon, which I live about 30 minutes from.
nickrohde121 is offline   Reply With Quote
Old 10-11-2014, 12:09 PM   #2
Default Re: styrene willys build
I like it, and will be watching this build. Once you reinforce the panels, and finish out the body, I bet it turns out real nice, you're quite the craftsman.
Mike Flea is offline   Reply With Quote
Old 10-21-2014, 09:51 AM   #3
So ive gotten some work done on it, still not finished but I did paint it up for a run I went out on. Dont have any pictures of the run, forgot my phone in the truck...
[IMG] photo IMG_0426_zps93092656.jpg[/IMG]
This is how it sat for the run, after that I did some detail decals and painted the rock rings.
[IMG] photo IMG_0438_zps65cb284e.jpg[/IMG]
[IMG] photo IMG_0439_zps44169938.jpg[/IMG]
These little decals were a royal pain in the arse, We couldnt get my mother in laws vinyl cutter to go into fine enough detail for the actual letters to work, so I used the cut off pieces as a stencil to paint them in, not perfect, but for how small they are I can accept it.
[IMG] photo IMG_0440_zps15acc76a.jpg[/IMG]
Old 11-02-2014, 08:05 PM   #4
Well After working on a cage out of styrene ( no access to my welding equipment for now) and having it break on the first roll-over, I got to thinking and thought of something simple. I still had the cage from the deadbolt laying around.
[IMG] photo image1_zps2edd7d39.jpg[/IMG]
It fit very well right off the bat, hugs the windshield tightly and fits the other over all dimensions. I simply had to make some extensions of the legs that would be strong enough, and I ended up using something everybody has laying around, clothes hangers. I drilled and tapped the ends and used some all thread to thread them on to the stock posts, then screwed the cage down to the body. I still need to paint it black but this gives you the general idea. Gives you an easy way to get to a strong cage that can and has taken a beating.
[IMG] photo image2_zpsa1ccf618.jpg[/IMG]
styrene willys build - Similar Threads
My first styrene build slash23 General Scale Talk 12 08-10-2013 11:39 PM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
Styrene build adamargue General Scale Talk 2 11-14-2011 07:27 PM
build with Styrene theclimber Newbie General 8 08-25-2011 04:43 PM
anybody build a FE boat in styrene? slowstang88 Non Crawler RC's 3 06-17-2009 07:14 AM
