01-14-2016, 06:23 AM | #1 |
RCC Addict Join Date: Jun 2006 Location: Maryland
| YB's little MFer
My little mythical Flatty that is... A good friend of mine owns a 1:1 flat fender with no lift and 35s that works amazingly, so I'm aiming to build something similar to it in 1:6 scale. Here's a picture from our Mediocre Adventure last summer and that's my Commando behind his MF. Low slung, leaf springs, and yota axles are three things that are a must for my first big willys. This pic is with .850 SLW hubs Started by cutting the ends off the RC4WD yota housing and cut the ends off of an old wraith housing to adapt VP chubs and knucks. I drilled out the plastic wraith spline pieces with a 27/64 drill bit. Then I chucked the yota housing in my drill press and used a file to turn down the ends to fit inside the 27/64 plastic ar60 splines. This axle wound up 1" narrower than a wraith axle but wider than a SCX axle. This is where I got incredibly lucky. A XR10 shaft slipped right in with ZERO modification. I can't be the first one to figure this out but I hadn't seen it before. Really blew my mind. |
01-14-2016, 08:43 PM | #2 |
| Re: YB's little MFer
Well this is interesting already. And I think you are the first to figure that out.. Xr10 width you say? |
01-14-2016, 09:10 PM | #3 |
Pebble Pounder Join Date: Oct 2014 Location: Santa Barbara
I think you stumbled on to something..... Subscribed swyped from my M8 with root privileges |
01-20-2016, 08:15 AM | #4 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Nice job, I need to narrow rear a tf2 housing by an inch, going to have to give this a try. Did you have a special jig to chuck it up in the drill press ? |
01-24-2016, 12:39 AM | #5 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
stop taking good picutres and concentrate on building!
02-01-2016, 06:53 AM | #6 | |
| Re: YB's little MFer Quote:
Finally got a 2nd housing from RC4WD and turned down the ends to run wraith rear lockouts. You'll notice I sand blasted the front chubs, there was just too much orange for a scale willys. I also ordered a willys cage from Super Shafty. The bends and brazing on this piece are brilliant! Very very happy with it! This cage is nice and light which seems to be a direction this jeep is headed. It also perfectly mimic's the cage in the 1:1 MF I'm duplcating. | |
02-01-2016, 03:08 PM | #7 |
Love that look. Hope it works out for you. How you gonna make it a flatty
02-02-2016, 10:03 AM | #8 |
RCC Addict Join Date: Nov 2008 Location: Frederick
Super Shafty roll cage looks great! Can't wait to see how you replicate the high line fenders, how are you going the build the frame rails? |
02-02-2016, 04:24 PM | #9 |
you could chop the fenders off and move them up. then chop the hood at the same level. i already know how to do it in my head. just cant do it in words.
02-02-2016, 07:37 PM | #10 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
I need to take a crack at one of these!
02-02-2016, 08:37 PM | #11 |
Rock Crawler Join Date: May 2011 Location: at your moms
you need to hurry up with this build, we need to have a willys trail run soon
02-16-2016, 01:26 PM | #12 |
| Re: YB's little MFer |
02-16-2016, 02:02 PM | #13 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
No update is meaningless as long as it has pics.
02-17-2016, 09:41 AM | #14 |
no., no. this is meaninglessfull glad i could make you the cage sir. just need to make a few more for some people Last edited by mjderstine; 02-17-2016 at 11:14 AM. |
02-19-2016, 06:07 AM | #15 |
02-19-2016, 06:14 PM | #16 |
Looking good Brian! |
02-19-2016, 06:48 PM | #17 | |
Standing by on this one. Quote:
VP steering parts have been put on yota axles before but ya, I think you are the first to figure out the setup without axle shaft cutting. I did the VP steering parts mod to my yota after seeing winnerone do it. I think Superdave did it a few years ago too. Szczerba's Flatbed TF2 ... | |
02-25-2016, 07:14 AM | #18 |
I've been hunting for stock axial xr10 rear shafts to test the "drop in" fit on my rear axle, but no luck. So I made a ugly ass jig to weld up my own rear shafts. MIG welded and straight as arrows thanks to the ugly vice grip/C clamp fixture. Added some gold paint for extra strength. Buttoned the axles up with the helical cut HD gears from RC4WD and some scale hardware on the third members. XR10-yota axles are done, time to work on that leaf sprung frame I've been avoiding. |
02-25-2016, 07:27 AM | #19 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
wow simply amazing!
02-25-2016, 07:50 AM | #20 |
Genius! Are these the standard yota axles or the 1/5th scale ones?
YB's little MFer - Similar Threads | ||||
YB's outrunner sportster | youngblood | Team Losi Comp Crawler | 70 | 08-17-2016 01:28 PM |
MFD CF Lil MFer with body. | MR.VERTICAL | Losi Mini-Rock Crawler | 88 | 01-09-2014 08:31 AM |
