03-13-2016, 06:23 PM | #1 |
Rock Stacker Join Date: Jun 2014 Location: myrtle beach
| First Ground Up Build 1/6 Jeep TJ with Clod Axles
A friend of mine gave me this body a while back, I have let my almost 2 year old son push it around the house. He has played with it so much the back wheels came off. I got the idea I wanted to build it and eventually give it to him as his first hobby grade rc. I went with the clod axles because that was my first hobby grade rc. The first thing I got for this build were the axles and that's when I realized I was in a little over my head. I contacted stangkillass from the forum to get some frame rails made up, when I did he started asking me questions I did not have the answers to. This is were you master builders come in. I thought I wanted tabs on the rails for the links to mount to, but he told me that wouldn't work very well. He suggested that I use scx, wraith, or narrow scx skid because there isn't a lot of space on clod axles for mounting shocks links or its narrow on the axle where they do mount I dunno so if anyone can help please speak up! I also need any guidance at all with the axles for mounting locations of links and shocks. Also im going to do some crawling with this but I do have a scx10 for comps, so this rig I wanted just a yard basher almost slash style lol. Really any help or point in the right direction is greatly appreciated! Well here are a few pics so you can see what im working with so far. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Last edited by mbcrawler08; 03-13-2016 at 06:33 PM. |
03-13-2016, 06:50 PM | #2 |
Newbie Join Date: Sep 2006 Location: quad cities
| Re: First Ground Up Build 1/6 Jeep TJ with Clod Axles
id love to find a body like that they are getting very hard to find. i used wraith axles with half inch wheel spacers, here my build thread if u want to check it out to give u some ideas on building it 1/6 scale nylint build |
03-13-2016, 07:53 PM | #3 |
I just scrolled through and checked out the pics walking dead on but any way that is really awesome so far bro. I unfortunately dont have access to a welder heck even if I did i have no clue how to weld. My build is more of a buy parts and hope it all comes together in the end!
03-13-2016, 08:45 PM | #4 |
Flip through these threads and find Bitter End's "Scrap Metal" build. He used Clod axles with a custom built frame
03-14-2016, 04:00 AM | #5 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
Looking at the body id have to say to go with the scx10 axles as they are narrower then the AR60s. Maybe using a 1.9 or perhaps a 1.55 setup? Sent from my LG-D852 using Tapatalk |
03-14-2016, 10:58 AM | #6 | |
| Re: First Ground Up Build 1/6 Jeep TJ with Clod Axles Quote:
03-14-2016, 03:06 PM | #7 |
That's very true. Im thinking scale shop chassis from stang killa ss and wraith skid. Im just having a hard time trying to measure to see if the link mount on the axles will work with the wraith skid. Like I dunno if it will put the links at to much of an angle using the wraith skid. I looked all morning trying to find how far apart the upper and lower links mount on the skid with no luck. I do know the lower links and shocks with the mounts i have ordered will be 6 inched apart on the axle. What do you guys think?
03-14-2016, 06:56 PM | #8 |
The links will be at less of an angle using a wraith skid than an scx-10 skid.
03-14-2016, 07:32 PM | #9 |
Wasnt sure how big or small this body was. My bad....go woth Ar60s then? Clod axles are to bulky and imo are trash anyhow Sent from my LG-D852 using Tapatalk |
03-14-2016, 07:56 PM | #10 |
Im going with the wraith skid just for link mounting locations. Im taking the body off the old chassis tonight to get all the measurements for the new rails. I also took apart the axles tonight to re grease them and I must say I have to disagree with you my friend. I'm sure the axles are years old and the stock plastic gears looked beautiful, cases were a little worn but still have tons of life left. If the ar60 stock is anything like a stock scx10 there is no comparison. Within a year or so I had to replace the bearings, lockers, ring, and pinion. So in my opinion a clod axle stock will outlast the ar60 10 to 1. You are right they are bulky as a mo fo tho!
03-14-2016, 08:07 PM | #11 | |
03-14-2016, 08:53 PM | #12 |
Scx10 were trash too...i didnt care for them either. However...i have 3 rigs now with AR60 axles and i love em. Sent from my LG-D852 using Tapatalk |
03-14-2016, 09:48 PM | #13 | |
03-15-2016, 12:23 AM | #14 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
I have the rare version of this jeep and it takes 40 series tires to fill the holes.
03-15-2016, 06:08 AM | #15 |
what is the difference between your super rare version and the one I'm using
03-15-2016, 06:59 AM | #16 |
| Re: First Ground Up Build 1/6 Jeep TJ with Clod Axles |
03-15-2016, 07:57 AM | #17 |
03-15-2016, 10:52 AM | #18 |
Mine should be very close to that and your link set up looks spot on thank you very much sir
03-16-2016, 04:54 PM | #19 |
I set the body up and put the axles underneath just to get an idea of what she would look like. I think the only prob I can see is there will not be much room in the rear for upper link mounts. the front is clear for days. [IMG][/IMG] front [IMG][/IMG] rear [IMG][/IMG] Last edited by mbcrawler08; 03-16-2016 at 05:05 PM. |
03-16-2016, 06:22 PM | #20 |
| Re: First Ground Up Build 1/6 Jeep TJ with Clod Axles Last edited by mbcrawler08; 03-16-2016 at 06:25 PM. |
First Ground Up Build 1/6 Jeep TJ with Clod Axles - Similar Threads | ||||
got some clod axles, what to build? | 87burb | General Crawlers | 6 | 03-20-2010 08:27 AM |
ground clearance with clod axles? | Rockinrockcrawler | Tamiya Clod Buster | 3 | 08-11-2005 07:08 PM |
